Home theater question
Old Dec 2, 2003 | 11:04 AM
spdy0001's Avatar
I now drive an accord....
I have a receiver that only has one optical input, altough most of my devices have digital outputs. I am only really concerned about having both my DVD player and XBOX hooked up with a digital connection. I think there is a "Y" adapter for fiber optic on the market but I can't find anyone that sells it. Anyone else run into the same situation and have a diffrent solution.
Old Dec 2, 2003 | 12:52 PM
proaudio22's Avatar
-S namyaC-
Re: Home theater question
Bad idea. Don't use any passive switchers. They make some active switchers, but they have some delay in the repeat. They aren't meant for A/V use, audio only. They run upwards of $400.
Does your reciever and DVD player have a coaxial digital input/output? If the reciever does, you can pick up a unit that converts the optical to coax, which works pretty good. I'll pull out some catalogs and get you some models if you want. Expect less than $100, maybe $50.
Old Dec 2, 2003 | 06:04 PM
spdy0001's Avatar
yea they both have digital coaxial input/outputs
Old Dec 2, 2003 | 06:07 PM
proaudio22's Avatar
-S namyaC-
So just use coax on the DVD, and optical on the XBOX. Problem solved. I like coax better anyway, it's easier to convert to the professional AES/EBU format.
Old Dec 2, 2003 | 06:37 PM
spdy0001's Avatar
I feel like an idiot, I though I could only use one or the other
Thanks,
Jeremy
Old Dec 2, 2003 | 08:17 PM
proaudio22's Avatar
-S namyaC-
No prob.
What reciever do you have? You can prob set the inputs to default to the right digital in.
Old Dec 3, 2003 | 04:37 AM
spdy0001's Avatar
I have an RCA thats about 2 years old, I know that I can switch between analog, coaxial, and digital for most of the inputs. I will pick up a coaxial cable tonight and try it
Old Dec 3, 2003 | 05:00 AM
hinrgdj's Avatar
The Midiman (M-Audio) folks make a neat box. The basic Co2 unit runs 50-70 bucks. If you want to strip SCMS get the Co3 unit.
Old Dec 3, 2003 | 09:45 AM
proaudio22's Avatar
-S namyaC-
You can defeat SCMS by simply using AES/EBU instead of S/PDIF. Most consumer audio CD dupicators have jumpers so you can defeat it too, they just can't sell them this way. The RIAA ain't got nuttin on us audio folk...
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
datadr
Sep 12, 2015 09:12 PM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
