Bypass Eclipse AVN5435??
Old Oct 27, 2005 | 12:25 AM
dabusabus1's Avatar
Does anyone know if there is a way to bypass the Eclipse AVN5435? I know there is a way to do it with the Pioneer's but i havent seen anything on the Eclipse units. Thanks
Old Oct 27, 2005 | 02:03 PM
StreetEffectz's Avatar
Tie the brake wire to the ground wire
Old Oct 27, 2005 | 08:18 PM
dabusabus1's Avatar
It's that simple? Thanks I didn’t know it was that easy. In your opinion which unit would you go for, the Eclipse AVN5435 or the Pioneer Avic-D1, and why? Thanks for your time.
Old Oct 27, 2005 | 09:32 PM
Well, the only thing I don't like about the D1 that the Eclipse unit has is that only has a 2volt preout where the Eclipse is 5V - other than that, I personally like the D1, hands down, and this is coming from a person who couldn't wait to get the Eclipse units in.
One big thing I don't like about the 5435 is the subwoofer control - you cannot turn the sub output OFF from the unit, and it only has 4 levels of volume control for it.
Old Oct 27, 2005 | 09:48 PM
dabusabus1's Avatar
Umm I’m not too familiar with what the voltage on the preouts really does. Could u enlighten me on that? And also doesn’t the 5435 have dual slots so u can play a DVD and navi, where as the D1 only play's navi and cd's? Also would I be able to keep the steering wheel control on both units for volume and track selection? And as far as the navi side of it, is one better than the other?
Old Oct 27, 2005 | 11:20 PM
demolition_x's Avatar
Agean Blue Bishes
if you ever wanted to run amps off the deck the signal pretty much sucks. most low end units have 2 but 4 should be the lowest and 5 is prob the best i have seen. if your not looking to add a sub or amped speakers i wouldn't worry about the 2v. or you can go the kenwood double din deck, but you have to buy the nav unit.
Old Oct 28, 2005 | 09:56 AM
phipark's Avatar
Not Asian
Yes, the Eclipse has both a dvd and cd slot. One to keep the Nav disc in and the other for CDs. The Pioneer only has one slot.
Old Oct 28, 2005 | 09:57 AM
phipark's Avatar
Not Asian
Maybe 5v is the best on a Nav unit. But my eclipse as an 8v pre-out with capabilities of 16v. However, only a few amps can fully take advantage of that high voltage.
Old Oct 28, 2005 | 10:58 AM
cazzy's Avatar
Took the words right out of my mouth!
Old Oct 28, 2005 | 11:22 AM
dabusabus1's Avatar
I am def going to be adding a sub and amplified speakers so it looks like I’ll be going with the eclipse unit. Thanks everyone for your input.
Old Oct 28, 2005 | 11:23 PM
GldCrzy's Avatar
on the d1 theres also 2 slots. though it says it can only play dvd-rom, if you do a bypass it can play dvds also.
to bypass, on the harness pop out one of the leftover wires including the pin, look for the empty slot on the opposite side of the ground wire, pop it into that empty slot and connect to a ground and your done.
then do the video lockout bypass as stated in other threads
tsx_boy
Dec 13, 2019 08:33 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
frozenpenguins
Aug 29, 2015 12:54 AM
