Throttle body coolant bypass
Old Sep 22, 2015 | 01:00 PM
Username 0's Avatar
I like cars.
Did any of you guys bypass the coolant lines that go to the throttle body?
Old Sep 22, 2015 | 01:04 PM
sure, but what are you really asking?
Do you need tips on how to do it?
Do you want confirmation that it works?
More info is needed from you!
Dont forget about the 5 W's. Who, what, when, where, why and How.
Old Sep 22, 2015 | 01:42 PM
ssjoeboe9's Avatar
ROTAREDOM
<p>No one does it.. I wouldn't worry about it. You should have just texted me haha</p>
Old Sep 22, 2015 | 02:41 PM
Username 0's Avatar
I like cars.
Actually I didn't need to know about it. This post was just an experiment (and or bet) as to who would be the first to reply to it. I knew it was going to be one of two acurazine members.
Old Sep 22, 2015 | 02:46 PM
you texted Joe, didnt you?
Old Sep 22, 2015 | 03:02 PM
ssjoeboe9's Avatar
ROTAREDOM
<p>I always answer haha</p><p>It's my nature to be helpful. Crabman only cares about statistics of his Azine Account!</p><p>EDIT** and to be fair... you posted in the performance section. Let's be honest there are like 5 performance CU2's on this forum haha. You had a small of pool to choose from.</p>
Old Sep 22, 2015 | 03:04 PM
pshhh.
post count means nothing.
Join date means everything!
Old Sep 24, 2015 | 12:16 PM
BaoZZeR's Avatar
I did it..
Old Sep 25, 2015 | 12:01 PM
richyrich1988's Avatar
make that 6..... my car does perform.... not very fast....but it performs...
Old Sep 25, 2015 | 05:19 PM
UTAH TSX's Avatar
Used those for turbo and wastegate cooling, SUCKERS GAVE ME 25 WHP at 8500 RPM
Old Sep 25, 2015 | 11:35 PM
iCrap's Avatar
TSX AMG Type //M i-VVT
Does bypassing it really make a noticeable difference? And what about during the winter, won't that shit just get stuck open?
Old Sep 26, 2015 | 01:50 AM
HondoGermany's Avatar
I have it for 3 years, no other big mods on motor. Dont think its for more hp. But cooler air is never wrong. No problems in German winters
Old Sep 26, 2015 | 11:40 AM
ssjoeboe9's Avatar
ROTAREDOM
I'm not risking it, we had days that were -14F last year
Old Sep 26, 2015 | 12:04 PM
Username 0's Avatar
I like cars.
I've never heard of someone's tb butterfly getting stuck before. This mod does lower iat temps. The coolant going through the tb keeps the tb around 180-200+ during operation. It's kind of like air going through a intercooler except it has the opposite effect.
I have seen someone install a small ball valve inline of the coolant hose to turn flow on/off.
I would imagine that a cai would really benefit with a coolant bypass.
Old Sep 26, 2015 | 08:55 PM
Username 0's Avatar
I like cars.
I just thought of something here.
Even if these coolant lines are hooked up, wouldnt your throttle plate freeze up if it wanted to anyways?? The throttle body only warms up as the engine warms up so when you start your motor after sitting in freezing temps over night during the winter it wouldnt make a difference if the lines are hooked up or not.
Old Sep 26, 2015 | 09:29 PM
thisaznboi88's Avatar
Do it!!
Old Sep 27, 2015 | 01:51 AM
Old Sep 27, 2015 | 10:32 AM
iCrap's Avatar
Yeah but as the motor warms up the tbody would also warm up. If the lines aren't hooked up it'll never warm up.
So say it is frozen when you start your car, well.. it'll just stay frozen then.
Old Sep 27, 2015 | 10:44 AM
Username 0's Avatar
I like cars.
The tb is surrounded by Heat sources to warm up.
Old Sep 27, 2015 | 12:22 PM
Old Sep 27, 2015 | 01:34 PM
you do know that the TB is under a high pressure spring and a motor that snaps it into place right? It almost chopped my finger while I was cleaning it because I got tired of pushing on it to clean out the carbon.
I drove my car in -20 degree last winter in WV. The throttle body didn't freeze shut. The only way it would freeze shut was if you got water into the actuator and it froze over night. There was a video about this controversy a while back on k20a about the coolant bypass. The consensus was that it was safe if you did it right and plugged up those holes.
TB freeing would probably happen easier in cars with cable throttle. There isn't a motor on it to force that mofo back into place.
Old Sep 27, 2015 | 05:01 PM
iCrap's Avatar
hmm alright. So it probably won't freeze.
But still, what is the actual benefit to doing the coolant bypass? Is there any definitive dyno proof that it gives a HP increase?
It seems to me like the air would be moving much too fast to actually be heated up by the TB. But i dunno.
Old Sep 27, 2015 | 09:14 PM
there no benefit unless you have other supporting mods. The air will still head up unless you have a therm barrier in placed like those p2r gasket. My manifold during wot run and everything upstream feels luke warm to the touch after a WOT run. That will be the only time you will see benefits. Lower IAT = more timing --> more power
for daily driving in traffic everything will heatsoak so it won't matter.
dyno charge provided as example from and LS motor
http://www.ws6.com/mod-8.htm
Old Sep 28, 2015 | 09:09 AM
xtcnrice's Avatar
VTEC just kicked in, yo!
Thanks for the explanation!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
