AVIC N1 bypass complete
Old Oct 24, 2005 | 05:27 PM
getright's Avatar
ny'r residing in maine
My brother (who i would say is the F*#@ing man) and i just completed the moving lockout bypass on my AVIC N1. We began by finding the green wire that runs from the head unit to the parking brake. He then cut it before the splice and placed it between the parking brake and the mechanism itself ( the mechanism is a plastic and metal piece that creates a circuit when the parking brake is activated). You will notice a hole in the parking brake lever that lets you access the screw to loosen the mechanism. Take the wire you cut that runs from the AVIC N1, strip the end, and place it between the mechanism and the parking brake itself. Use the screw to tighten the wire between the two and this will complete the circuit and make the head unit think that the parking brake is always on. Therefore you will have control of all the locked out functions while moving such as address search and dvd playback. This took a total of five minutes and is easier than you think. I was running version 1.2 pioneer navi disc and had no problems with all functions. We did a test run and got up to about 55mph and had no problems. I now love my AVIC N1 a million times more. No i will not be using this to distract myself form the task of driving, just to make the unit alot more usable in the real world. I will post pics tomorrow as it is now too dark to do so. Good luck and enjoy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 24, 2005 | 05:33 PM
gmfreed's Avatar
Cant you just ground that wire? I am pretty sure you can
Old Oct 24, 2005 | 05:38 PM
BEETROOT's Avatar
Yeehaw
yep
Old Oct 24, 2005 | 05:43 PM
NYZGREATST's Avatar
Sig Rho's Finest
hmmm thats a long process for something that can be done yb just grounding the parking brake wire. now ask him to crack the N2 - THAT WOULD BE AN ACCOMPLISHMENT WORTHY OF PRAISE
Old Oct 24, 2005 | 05:51 PM
getright's Avatar
I did it without soldering or grounding anything and as i said it only took five minutes just alot of words to describe and at this point with all the bullshit you need to do to bypass an N2 i wouldn't even bother
Old Oct 24, 2005 | 06:14 PM
MeldyS26's Avatar
is still kickin!
i grounded it and it took me about 2 min
Old Oct 24, 2005 | 06:35 PM
getright's Avatar
2 mins? that's pretty impressive bro, you sure about that?
Old Oct 24, 2005 | 09:27 PM
NYZGREATST's Avatar
Sig Rho's Finest
yea thats how i did it in my dads car. before the stupid N2 is was simple to do the bypass, just tap the parking wire to the ground of the headunit.
Old Oct 24, 2005 | 10:26 PM
StreetEffectz's Avatar
The N1 has no gyro blockouts - all you do is tie the green wire with the black ground wire, DONE
Old Oct 24, 2005 | 11:30 PM
red99cl2.3's Avatar
who got the best deal?
easssyyy
all you gotta do to bypass the N2 is look on the bottom side of the unit you will see a little brown piece of tape or covering once you remove that you will see two soder points all you gotta do is put a wire between these two points BE VERY CAREFUL!!!! and thank your Pioneer rep!!! this was very useful info we;ve tried it on two units so far with no problem. if this works for you all i ask is that you PM me and let me know thanks
Old Oct 24, 2005 | 11:38 PM
getright's Avatar
it's been in this thread for a while give it a try NYZ, here ya go
Old Oct 11, 2008 | 01:28 PM
123carsolutions's Avatar
4th Gear
Avic N1 Bypass
Heres a good site that has alot of bypass guides for Pioneer Avic Units:
Click Here For Avic Bypass Guides
Guides for Pioneer Avic D1, D2, D3, N1, N2, N3, N4, Z1, Z2, Z3, F700BT, F900BT & F90BT.
Old Oct 11, 2008 | 02:21 PM
Blind_Shooter's Avatar
For Life
so you wasted a bunch of time doing something that wasnt necessary because you didnt know you could ground out the wire.
thread= EPIC FAIL
Old Oct 15, 2008 | 07:49 AM
macro76@yahoo.com's Avatar
so whats the best fix? i havent installed it yet but i wanna slove this b4 i do. soder or ground? by the way meldys26, im albanian too
Old Oct 15, 2008 | 09:15 PM
achenator's Avatar
Can I ground the unit, the parking brake and the mute all to the same place??
Old Nov 1, 2008 | 07:45 AM
ice2fire11's Avatar
AVIC411.com will answer all these questions.
tsx_boy
Dec 13, 2019 08:33 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Jimmy_D
Oct 7, 2015 11:52 PM
hashbrown
Sep 29, 2015 12:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
