Throttle lag
Old Sep 9, 2019 | 07:38 AM
anthony.montana's Avatar
Throttle lag
Curious if anyone else has experienced throttle lag, where when I step on the gas the response is not immediate, I have the motor shut set to on so the motor does not stop when the car comes to a stop. I experience this anomaly from a stand still, if the car is traveling at lower speeds, In the 30-40 MPH range. It is very noticeable when attempting to pull out into traffic from a dead stop. I had this on my 2016 and also on my 2020. Both of these vehicles were equipped with the V-6, both were TLX SH-AWD and both had the tech option package, the 2020 has the A-Spec package, The 2016 was turned in with 25k miles and I gas the car from the same pump the majority of the time. Any feedback would be appreciated, thank you.
Old Sep 9, 2019 | 06:11 PM
Rocketsfan's Avatar
Many have reported the throttle lag, but it varies. When I bought my car back in 2014, I noticed it from a stand-still while trying to get into a median or when I was attempting to make a right-turn (for whatever reason). Others have also stated the "right-turn" sluggishness. My car seems to behave much better but occasionally the sluggishness rears its head, but I don't risk flooring it to merge with traffic or cross a street much anymore. What mode are you in? Eco, Normal, Sport, Sport+? If you're in Eco, that could be one reason. If you're in Normal, it may still appear. I'm always in Sport mode now, and it occurs much less - I don't know if there's a direct connection with that or not or if that's the only reason.
Old Oct 23, 2019 | 06:40 PM
Trust037's Avatar
From what I've read it's just the way drive by wire is. I felt alot of throttle lag. Some people will tell you to disable the traction control but what I found to reduce the lag was installing a sprint booster.
You should find someone with a sprint booster installed and compare. I have a 2018 Aspec AWD and the added sprint booster was worth it.
Old Oct 24, 2019 | 05:41 PM
dezymond's Avatar
Yes there is a bit of throttle lag and you kinda get used to it. I've owned my TLX since Nov 2016 and got used to it. I recently installed a VCMMuzzler and I feel that's mostly fixed the issue or at least has minimized throttle lag significantly. Others have also said Sprint Booster helps so you could try that too.
Old Oct 30, 2019 | 05:08 AM
jhb31's Avatar
I also installed the vcm muzzler. Takes two minutes to install and the difference it makes is really amazing. Has me thinking about keeping the car a year or two longer than I intended. I didn't think all the good posts about it were true but glad I finally gave in and got it.
Old Nov 6, 2019 | 04:30 AM
TSXV6Guy's Avatar
Completely agree. I also installed the VCM muzzler and it makes a HUGE difference. The TLX feels completely different.
All this time, I thought the TLX lag was due to the crappy ZF9 transmission. But with the muzzler, I just realized it's the Variable Cylinder Management of the V6 engine that is the culprit. I am baffled that Honda's engineers were not able to get this right! I always thought the VCM would only engage under specific conditions, like highway cruising under low load.
In any case, with the muzzler, I am enjoying the car much more (within the ZF9's limitations, which are now tolerable...).
Old Feb 20, 2020 | 08:27 AM
canadian_cop's Avatar
9th Gear
I’m interested in installing this into my ‘18 TLX A-Spec. Huge lag.
Where would you suggest I buy one? Preferably Canadian source but open to any
Old Feb 23, 2020 | 09:47 AM
TSXV6Guy's Avatar
Look for "verbatim" on the Honda Odessey forums.
dilaxo98
4G TL Problems & Fixes
Jan 1, 2018 04:38 PM
txl2017
Sep 12, 2017 09:49 PM
Slithr
Mar 27, 2013 11:29 PM
rob-2
Dec 8, 2008 07:54 PM
soundgarden
Sep 27, 2004 09:37 PM
