Replace battery in the MID screen
Old Sep 6, 2014 | 10:34 AM
jdm_fanatix's Avatar
I have been having this replace battery in the mid screen, battery light and acuralink message come on and off almost every time I'm driving for the past week on my 12 tl sh and wondering if anyone else has this issue. I changed the battery from oem to acdelco with 700 cca last year and have had no issues since. I also took the car to advance auto and had the battery tested and it was good beyond oem specs. I dont really want to replace a good battery or think i can get a warranty on a battery thats testing good. Any suggestions? I have read the tsbs but they only talk about the mid screen showing charge low...
Old Sep 6, 2014 | 02:53 PM
Mr Marco's Avatar
One of the most common issues with automotive batteries is the ground connection. Corrosion can occur UNDER the negative terminal. It is often overlooked and when tested the battery will show as good (because there is nothing wrong with the battery). This would be the first place I would look for trouble.
Old Sep 6, 2014 | 03:03 PM
EE4Life's Avatar
Forum Contributor
You can also try and reset the battery management system after the battery is charged. Disconnect the gray 2P connector next to the battery
negative cable for 10 seconds, and then reconnect it.
Old Sep 6, 2014 | 03:08 PM
Mr Marco's Avatar
No^
OP, just take the negative terminal off and inspect for corrosion. This process will also reset the ECU.
Old Sep 8, 2014 | 01:04 PM
Originally Posted by Mr Marco
No^
Thanks ill give that a try today. It doesnt look like there's much corrosion at all the last time i checked.
Old Sep 8, 2014 | 08:08 PM
arek1200's Avatar
I just had my battery replaced by a dealer, no corrosion at all on the terminal....it simply died one day with no warning....
Old Sep 8, 2014 | 11:33 PM
yup that's what happened to me last year but I didn't know my battery was covered under warranty so I replaced it with an aftermarket and its been good since... except the past few weeks.
Old Sep 9, 2014 | 08:47 AM
dirtyo2000's Avatar
Is it for the key fob or actual car battery.
Old Sep 11, 2014 | 01:58 PM
TLTesh604's Avatar
Do you get 'replace battery' warning before your battery craps out as well? I have an 09 with stock battery still going strong I feel. I have a battery sitting in the garage waiting but stock still has not gone yet.
Old Sep 11, 2014 | 06:07 PM
arek1200's Avatar
I got no warning, one day all is fine...the next morning all I hear is clicking sound, cluster flashing and silence...
Old Sep 12, 2014 | 03:03 PM
after disconnecting the terminals there was no corrosion. i did notice that it was a little loose though. I greased them up and tightened up the connections. so far so good!
Old Sep 17, 2014 | 04:40 PM
mhbill's Avatar
I hope one of the above 'solutions' works for you. However, my experience leads me to believe the problem is a sensor/firmware issue. I have had this message occur since purchasing this car (3 years ago). The message comes and goes, but the car always starts. Acura has tested the electrical system several times, but has not found a 'problem'.
Old Sep 17, 2014 | 04:46 PM
acrdr's Avatar
On some there was a software update for the battery maint minder system
Old Dec 6, 2014 | 10:30 PM
illistik's Avatar
I just bought an used 2012 Acura TL about a week ago and the battery crapped out yesterday. I had it jumped and the car was running fine. I took it to the Acura dealership the next day and asked to replace the battery since there was some corrosion on it and figured the battery was on its way out. However, they insisted the battery was still good and that there was a draw on the battery, but weren't able to locate the source of the draw. Has anyone encountered this issue before on their 4G TL?
I read in the 3G TL section there was an issue with the HFL system not shutting down completely once the car turns off, leading to battery drainage.
Old Dec 6, 2014 | 10:36 PM
acrdr's Avatar
How a dealer can not figure out the draw?
They have the training for that diag
Old Dec 6, 2014 | 10:43 PM
illistik's Avatar
Well, they said they needed more time to diagnose, but I was just wondering if anyone else had this happen to them and where the draw was coming from?
Old Dec 6, 2014 | 10:45 PM
acrdr's Avatar
Most common was hfl on either tl or mdx
But also a/c relay would stick on them as well and drain the battery
Old Dec 6, 2014 | 10:58 PM
illistik's Avatar
Great, appreciate you feedback. I'll mention those items to them. Hope I can get this fixed soon.
Old Jul 5, 2015 | 07:36 PM
CRJ04121990's Avatar
From the time I picked up my 2012 TL from the dealer it's had intermittent issues with battery warnings. The dealer checks the system and finds the battery is fine. About a month ago the battery just died with no warning whatsoever. Right in the middle of a car wash which was very inconvenient.
The dealer replaced the battery at no charge, but about a week later I began receiving a battery low message each time I started the car. The vehicle turned over with no issues turning over. The dealers claimed that the battery management system just need to be reset. I did not get the error for 3 days, now it's back. I'm bringing it back in.
Old Jul 5, 2015 | 11:45 PM
echodigital's Avatar
From TL to RDX
The car has a lot of draw for power. For example, when using a AC compressor to fill up air in my tires, I have started to run the car, I don't want it to drain the battery. I had once run the radio for 30 minutes and it drained the battery as well. It was 2009 model so it didn't have the 2012 battery management system.
Old Jul 7, 2015 | 06:21 PM
Reorge's Avatar
There's a TSB that might correct your problem.
12-013
Applies To:
2012 TL 2WD – From VIN 19UUA8...CA000001 thru 19UUA8...CA008239
2012 TL SH-WD – From VIN 19UUA9...CA000001 thru 19UUA9...CA002516
(search other threads for a copy)
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
