Oil consumption
#282
As I posted in another thread on the same topic, if you got the same letter I did, I'm not certain what good the test will do unless you qualify for the 8 year/ 200,000 km extended, since the "interim" warranty will be up before your test is complete. If your in-service date is late 2011 or later, you should be fine.
#283
#284
When I dropped my car for the oil consumption test, they never did an oil change. They just top off the oil and ask me to come back after 1000 miles.
#285
So I got the car back after Acura did the oil change and airbag recall. I checked the dipstick after I got to work and they did change the oil and it was topped right up to the line. They said to come back when I notice the level go below the bottom line or when I hit 1500KM, whichever comes first. Although, the service guy told me that my oil pump is leaking. I highly doubt the oil pump leak is the cause to this. But they said they'll still do the consumption test and see what the results are. The service guy seemed pretty aware of the oil consumption issue. Other than that, the service was good at this dealership, it went smooth and they didn't even try to upsell me anything.
Here is a picture of page 1 of the invoice if it helps anyone.
#287
Just an update from my last visit to Acura. Last week I noticed there was no oil on the dipstick so I called to make an appointment. When I checked the dipstick I was at 910KM but by the time I got an appointment with Acura and brought it in, I was at 1275KM. So according to them, I lost 1.7L in 1300KM. I will update on my next visit.
#288
I always forgot to look after an oil change... To verify the dipstick.
I really expected the dealer wasn't adding enough oil to the car during the oil change!
I've been dumping in 3-4 quarts between changes for 5 plus years. :/
Has anyone been offered cash instead of the labor intensive work required to rebuild the engine? I haven't read the whole thread...
#289
My letter said all vehicles will be covered regardless of age or miles until September 2019. Plenty of time.
#290
#291
Maybe its 6 months after they send you the letter with different people getting the letter at different times.
Im not sure its true but I would also assume that you really only need to START the test within those 6 months because if you think of it, what if you don't drive your car a lot? What if it takes 8 months to drive 4500 km (1 liter burnt in 1500 km x3)?
It took me pretty much 6 months to drive the 3750km it took my car to burn 3 liters.
#294
In my case, it looks like it doesn't matter anyways. I started my test in February, and am now down to 70-80% oil life, and I'm still showing plenty of oil on the stick. Doesn't appear that I've got a problem.
#295
Just another update, I took it into Acura today after noticing there was no oil on the stick this morning. I have driven 800KM since the last visit. They told me I lost 1.7L again. The lady told me I most likely will be getting the warranty parts replacements. So figures crossed. But I still got 1 more test to do. Which doesn't seem like a long time at the rate it's burning the oil. Will keep you guys posted.
#296
Sorry to sound like an ass, but I don't think we need to hear every detail about how the dealer is treating everyone during their oil consumption tests. It would be much more beneficial and interesting if people would report back AFTER their cars are fixed and what their impressions are of the service they received, other components they had replaced at the same time (timing belt, water pump, etc), if they've noticed an improvement in fuel economy, engine performance, etc.
#297
This is what this forum is for. Contributions and feedback. If its not helping you, it will definitely help someone else. So think about other people before you start speaking on behalf of everyone.
KidK (03-26-2021)
#298
Another update: I went in for the last phase of the test today after I noticed no oil on the stick. They said I burned 1.1L and I drove 800KM since the last visit. They said I'm approved for the replacements but I'm going to have to wait to get it done as they need to order the parts. I'm taking it in on Aug 26th.
echodigital (06-25-2019)
#299
Less than required to qualify... So far.
After starting my consumption test, looks like I am at 1qt per 2000 miles.
Service quantified it's 1qt per 1000 miles to qualify for the repair.
Also, said I can take it in every 1000 miles until.......September. Then, it's over.
While I'm not exactly upset I don't qualify, I still think it's excessive consumption. I'm not looking to get the repair completed just for the sake of getting a rebuilt engine...at least not enough to push the issue. But.. if I qualify... I qualify... and would want the work completed to fix the problem. I've never had to add oil between changes to any car I bought after, at least, 1995.
But at least until September, I'm getting topped off every 1k miles. Paid enough for the car... I'm getting my nine dollars in, well deserved, oil!
#300
I've stopped on 06/25/9 by Syracuse Crest Acura to get a time frame as to when my car will be getting repairs done. Service adviser informed me that they are out of some parts and did not provide me even with an estimate.
#301
Received the recall notice for my /12 TL in December and began the testing shortly after. During one of the test visits to the dealer, they noticed the rear valve cover gasket was leaking and I had them repair it.
Went in for the recall service at the beginning of June. Work took 2 days, and I had them do the water pump and timing tensioner while they were in there. Haven't noticed any significant improvements in fuel economy or performance since, but glad it was done as I'm just rolling over 200,000km.
#302
This is a follow up post for my Oil Consumption test.
The test started on December 27, 2018 and ended July 31, 2019. I don't drive as much as now a days which may explain the longer testing period.
Results are:
For those who are curious, I bought the vehicle used from the dealership it had about 9,000 KM on it when I bought it. I noticed that it started to consume oil around June of 2017. Since then I checked the oil levels monthly and topped up the oil as needed.
I received the letter from Acura Nov 2018, at that time I already did an oil change outside of the dealer. I decided to get the oil changed again at the dealer so I can start the test without waiting till the next oil change. Based on my driving habits this would have been in July of 2019. I should also note that I was due for Service A13 at the dealerships recommendation I held off on getting the servicing done until the test was concluded. By the time I had the servicing completed I was about 500 KM overdue.
Some key items I learned through all this is,
I am located in Edmonton, Canada the dealership I am working with is West Side Acura.
Hopefully this helps everyone going through the test or about to start the test.
I'll post another follow up post after the engine work is done, which I hope is in December.
Results are:
- Dec 27, 2018 at 141,239 KM was when the test started.
- April 12, 2019 at 145,328 KM was when oil level reached the lower mark. I brought it back to the dealership where they topped it up.
- May 27, 2019 at 146,459 KM the oil level reached the lower mark again. I brought it back to the dealership where they topped it up again.
- July 31, 2019 at 148,759 KM the oil level reached the lower mark. I brought it back to the dealership for a final analysis and to determine if I qualify for the engine work needed to prevent this issue from occurring again.
- Check the oil levels when the engine is hot. That was the direction the dealership gave me.
- The oil levels have to be at the lower mark or below it. If it is even slightly above the mark, the dealership will tell you to come back. I had this happen twice where the oil was just above the lower mark.
- I checked my oil levels weekly and took photos. However, the dealerships won't use the photos.
#303
2013 covered?
HI,
I am buying 2013 TL from my daughter which she bought in 2016 from a non Acura dealer.
I don't think she received a recall letter.
Car now has 94K miles. I will have to check with her if car is losing oil.
Is 2013 covered in this recall?
I entered the VIN and it came up empty.
Robert
Robert
#304
HI,
Robert
Robert
#305
HI,
Robert
Robert
charge.
#306
HI,
Robert
Robert
#308
Yes SH-AWD
Thank you all,
Yes mine is 2013 SH-AWD.
I did change oil today and noticed it very dirty (may be specks of flakes? Not metal)
I will call dealer tomorrow to setup an appointment.
My daughter had the car serviced at other Acura dealer but I will get records from her...
VIN lookup shows this...
hyperpm
04-30-2016 08:14 AM
