Jump Drive doesn't work
Old Sep 26, 2009 | 05:09 PM
snowmanTL's Avatar
snowmanTL
Trying to upload additional photos to the HDD (BTW I have a '09 TL w/Tech Package). The system keeps saying there are no files located on the drive??? Anyone else experience this problem?
Old Sep 27, 2009 | 03:15 PM
benzboy429's Avatar
yup same problem tried to zips, neither work
Old Sep 27, 2009 | 04:06 PM
benzboy429's Avatar
when you format you select fat system and quick format, but what do you select for allocation unit size? it automatically selects an amount, should i be changing that?
benzboy429's Avatar
Old Sep 28, 2009 | 11:22 AM
danimal1968's Avatar
I have 3 jump drives. My TL will not read one of them.
Old Sep 28, 2009 | 11:32 AM
Haelous's Avatar
If it sees the flash drive, have you tried putting an MP3 on it to see if it will play? If so, it is very possible it is an issue with the pictures.
Nope, and it is not necessarily the case that the drive needs to be formatted.
If your flash drive has something similar to Sandisk's U3 Launchpad on it, you should first remove that with the U3 Launchpad Removal Tool.
Old Sep 28, 2009 | 07:36 PM
Olu's Avatar
Olu
https://acurazine.com/forums/showthr...ht=flash+drive
check my post #30
Old Sep 28, 2009 | 08:47 PM
snowmanTL's Avatar
snowmanTL
Got it work. Used a generic USB drive. It can't have any files on it at all, which the newer USB drives usually do. Also make sure the pictures are .jpg not .jpeg as it states on the error screen.....
Old Oct 1, 2009 | 10:08 AM
wsurandy's Avatar
5th Gear
Doesn't it say in the manual that flash drives don't work?
Old Oct 1, 2009 | 12:53 PM
Olu's Avatar
Olu
2009 TL Navi manual
"Importing Pictures from USB
To use a wallpaper image other than the factory defaults, you can import pictures from a USB thumb drive or similar device.
Thumb drives use flash memory.
Old Oct 24, 2009 | 03:40 PM
Outlaw06's Avatar
Has anyone tried to plug 500 GB external HDD?
Old Oct 24, 2009 | 04:07 PM
Olu's Avatar
Olu
I reformatted a 250gb external USB drive and it didn't work.
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
tonio
Feb 5, 2019 05:43 PM
jordanboi
Sep 5, 2015 01:33 AM
