HID issues
Old Jun 30, 2022 | 12:39 AM
4genTL.awd's Avatar
4th Gear
HID issues
I have a 2012 TL. My passenger side headlight went out so i replaced the bulb and it didn’t work. Then i bought a ballast and replaced that as well with the new bulb, worked for 2-3 weeks and went out. Is this a common issue? I’ve had the car only about a month and a half. And what could possibly be the problem now? Why did it burn out so fast?
Old Jun 30, 2022 | 03:02 AM
Where did you buy the parts
Old Jun 30, 2022 | 04:53 AM
4genTL.awd's Avatar
4th Gear
ballast on Amazon and builds from autozone
Old Jul 1, 2022 | 03:48 PM
csmeance's Avatar
It could be a bad ballast from autozone, but best thing to do is check all wires and grounds and connections first.
Ideally, you should have swapped parts from working side to non working side 1 at a time to figure out what the problem was before buying parts.
You can buy OEM used ballasts for $40-50, and most HID bulbs are very bad on the market. Stick with good bulbs from a place such as theretrofitsource.com they also sell used ballasts.
Confusednewb
Nov 16, 2016 02:13 PM
dlphnsjk
Apr 27, 2015 05:06 PM
kqxqx
Aug 26, 2014 03:58 PM
kdawg8526
Oct 20, 2009 12:04 PM
turbo tecnica
Oct 22, 2008 02:30 PM
