HID Headlight Problems
Old Apr 25, 2015 | 08:39 AM
dlphnsjk's Avatar
Hey guys long time member just haven't posted in a while. Had a question about my headlights. The driver side HID bulb went out a few weeks ago and the passenger one will come on sometimes but most of the time it wont come on at all. Electrically everything else with the car works fine and I just had my battery and alternator replaced (the light problem started before I did this). So I was wondering if this is just a simple HID bulb replacement or if its a more complicated problem. If anyone can help I'd appreciate it thanks!
Old Apr 25, 2015 | 09:59 AM
dezymond's Avatar
Try replacing the bulbs and see if it works first. That's the easiest way to find out.
Old Apr 25, 2015 | 10:43 AM
dlphnsjk's Avatar
yeah that was my first plan of action..scared its the ballast or ignitor .. are those hard to replace or expensive?
Old Apr 25, 2015 | 10:58 AM
Dumpedsi's Avatar
To remove the ballast you'll need to remove the front bumper, it not too bad though.
Swap which side the bulbs are on and see if the issue follows the bulb. That will give you a better idea if its the bulb or something else.
Old Apr 25, 2015 | 11:27 AM
fishin412c's Avatar
Bulb = $105 (plus)
Igniter = $180 (plus)
Control Unit = 180 (plus)
Old Apr 27, 2015 | 05:06 PM
ROSSARONIE's Avatar
You can g o through the wheel well and take off the wheel. There is a tamper proof bolt on the hid cap.
I had the same problem replaced the light and the new light didn't work. It eventually tied back to a problem with battery brain cause d from my bluetooth.
tman570
Jun 11, 2019 07:56 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Silverstead1
Sep 17, 2015 06:45 AM
JnC
Sep 11, 2015 06:06 AM
voigt
Sep 2, 2015 10:44 PM
