A/C compressor
Old Aug 21, 2018 | 10:03 PM
Humam Abd's Avatar
3rd Gear
A/C compressor
My compressor coil is working and the system has Freon but no cold air , is the compressor went bad and how to take it out
Old Aug 22, 2018 | 11:19 AM
dv-'s Avatar
dv-
You'll want to have the system emptied by somebody who knows what they're doing. When they empty the system, the readings on their pressure gauges will be able to tell you whether the compressor is working or not, or if there's a leak, etc.
Then to replace the compressor you just follow the procedure in the shop manual.
https://acurazine.com/forums/fourth-...manual-956811/
Old Aug 22, 2018 | 03:28 PM
Humam Abd's Avatar
3rd Gear
I have emptied the system and I have ordered recharge and vacuum gauge and I would like to know how to test it , should I connect the gauge to the high pressure connection and turn it on or what? , thanks
Old Aug 22, 2018 | 03:55 PM
dv-'s Avatar
dv-
Where'd the freon go, eh? :-P
First, you put negative pressure on it with a vacuum pump to make sure it can hold vacuum (so, verify that the system is not leaking.)
Then when you refill it (watch some youtube videos to see the process) the compressor has to be working. If you run into a problem like, say, your low and high side pressures are the same, or the compressor isn't sucking refrigerant into the low side, then you know you've got a busted compressor.
Old Aug 23, 2018 | 11:29 AM
Blaze9's Avatar
Chris Fix on Youtube has some fantastic videos, and talks about recharging and replace the compressor. It's not a TL but the steps are the same. Just need to figure out the locations for everything. The shop manual has all the info you need to supplement the video.
Replace Compressor manual: https://drive.google.com/open?id=0B7...ENFb1NZVTN1UGM
Replace condenser manual: https://drive.google.com/open?id=0B7...0FXMDZVR0htRkE
Replace Compressor:
Recharge System:
Old May 19, 2020 | 08:08 PM
mmuschamp's Avatar
7th Gear
Hey Blaze!
Sorry to re-open an old thread. But when you replace the AC Compressor, is it necessary to replace anything else? My compressor has been making a grinding noise and im pretty sure its shot. I couldn't find any specific guides on the 2009 TL and was wondering.
Old May 20, 2020 | 12:27 AM
csmeance's Avatar
Originally Posted by mmuschamp
Hey Blaze!
Replace the dryer element inside the the A/C condenser and make sure there are no metal flakes on it. If there are metal flakes you'll need to clean out the A/C system to remove the fragments otherwise it'll kill the new compressor.
Old May 20, 2020 | 07:08 PM
mmuschamp's Avatar
7th Gear
thanks for the reply. Ill Be sure to make sure I take a look at this. I struggle to find any detailed guides on this process. Is it a difficult process to trace the dryer element? Any specials tools r extra materials I will need?
Old May 21, 2020 | 12:32 PM
csmeance's Avatar
It should unscrew from the side of the condenser in front of the radiator. Just lookup A/C drier replacement honda and you'll see lots of videos.
tsx504
1G TSX Problems & Fixes
Mar 16, 2015 10:22 PM
scottthomp
Sep 3, 2012 08:47 AM
Toddy
Aug 28, 2012 02:16 PM
Shawn S
Wash & Wax
19
Feb 10, 2003 09:23 AM
