Ugh, oil pump is leaking
#121
There is nothing wrong with used oil pump if you buy one in good condition. You bought a used car didn't you?! Everything is old on it. I installed one off an Honda Odyssey when I resealed the oil pump on another J series in the past, no issues. Used oil pump here... nothing wrong, 30k miles now.
#122
PIC
PIC
#124
It's working great and the Grey honda bond from the tube version also worked great but was a little tedious to apply.
I believe there were two internal oil pump seals in the kit also as I could not find where else they would go on the stuff that should be replaced.
Kingcredible (11-16-2020)
#126
Yes. Timing belt + oil pan + oil pump must be removed. I'm doing this right now and it's a big job. You just had your timing belt done, if I were you I'd wait for the next timing belt replacement unless it's leaking really bad
#128
Just on the safe side from something like that happening shortly after the service is why I believe several people recommend it be done whenever the timing job is being done.
I will try my damnest to do it every interval because I know when I don't it will bite my butt.
