TPS P2123 Code
Old Aug 1, 2024 | 07:01 AM
07TLTypeSlow's Avatar
TL-S
TPS P2123 Code
Hi guys been having this problem with my 07 TL Type S it had a code for the APP and TPS sensor so I replaced the APP sensor and that got rid of most of the problem and stopped from going into limp mode constantly but it still had the TPS code P2123, the car will go into limp mode only if I put the gas pedal to the ground and no other time it drives as normal otherwise so I was just wondering if it’s just a bad APP sensor still or if I have to replace the whole throttle body to get a fix or can I just try cleaning out the throttle body to get a resolution any input is appreciated thanks guys
Old Aug 1, 2024 | 12:33 PM
where did you get the replacement App sensor?
https://acurazine.com/forums/3g-tl-p...-730958/page6/
Old Aug 1, 2024 | 12:36 PM
TL-S
Amazon, you think it’s because it’s not oem?
Old Aug 1, 2024 | 12:49 PM
Old Aug 1, 2024 | 01:57 PM
Post up a link if you can.
Old Aug 1, 2024 | 04:14 PM
TL-S
Amazon
Old Aug 2, 2024 | 06:23 AM
Here's what rockauto offers, if interested:
Old Aug 2, 2024 | 06:27 AM
TL-S
feel like I should still go oem with this one
Old Aug 2, 2024 | 08:58 AM
Indeed.
I was just showing the 'middle' ground aftermarket selection (cost wise) as a comparison to the least expensive (from the mainland) versus the preferable expensive OEM product:
I understand that taxes / import fee's & such hammer you all up that way, .
Old Aug 2, 2024 | 09:04 AM
TL-S
Indeed.
yea $313 is nuts for oem I think I’ll try to get one off a parts car tl first before I drop the cash on that, easy install so if it doesn’t work that’s fine
mayjarjar
Jan 14, 2019 06:12 PM
LowMiles_BlueTL
Nov 3, 2014 02:39 PM
170155
Aug 1, 2013 07:57 AM
boredmug
Jul 11, 2012 09:30 AM
heyitsvu
May 15, 2009 02:34 AM
