P0505 IACV, replaced it, but still having the same problem.
OM NOM NOM NOM
Okay guys I recently had the IACV valve act up on me again. I cleaned it out, but still no goose. I picked up a used throttle body from a 2002 TL-P and removed the IACV, cleaned it, and replaced it, but the problem is still there!
Another thing is that I recently bought a universal o2 sensor to replace the primary o2 that went out on me. I occasionally get a P0135 code for the o2 sensor, so what I'm wondering is whether this o2 sensor could have anything to do with the P0505 code I'm getting? If i reset the ECU, the rough idling problem goes away for a little while, and sometimes just turning the engine off and on will get it going normally for a while again. It revs up and down from 1000 to 1500-1700 rpm, then drops to 1000 again.
Thanks in advance for your advice guys!
OM NOM NOM NOM
Problem was never found, but i got rid of the code. Went to the yard today to pick up a used type-s throttle body. however, when i got home, i purchased 4 bottles of carb cleaner, and sprayed down the whole intake manifold. then i installed the throttle body, and the car feels totally different. not sure if the throttle body fixed it, but a combination of everything solved the problem. just thought i'd update you guys on it. waiting for my o2 sensor to come in to solve the last problem
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
