TL-S not starting?
Old Sep 24, 2009 | 02:26 AM
baldyxp's Avatar
TL-S not starting?
Well I have a pretty much stock TL-S only mods are HID fogs and led interior lights/license plate lights. I went to go start my car, put the key in the ignition and turn it. Nothing happens no lights or anything so I try to start it three more times and nothing. The engine doesn't even turn or even make a sound just absolutely nothing happens. So I pop the hood to see if someone stole my battery but everything is there. I went to start the car again put the key in the ignition the dash lights up and the car starts.
Now the weird part is I have to put in my Nav and Radio codes. Has this happened to anyone before and do you know what could have caused this?
Old Sep 24, 2009 | 04:24 AM
erick3's Avatar
probably has something to do with your terminals. you're still under warranty...take it in to the dealer.
Old Sep 24, 2009 | 08:06 AM
LoveMyTL-S's Avatar
Lose battery terminals? Corrosion? Perhaps your ground cable is lose?
Old Sep 24, 2009 | 08:23 AM
Bearcat94's Avatar
AZ Community Team
Could be a bad battery.
A couple months ago, I drove 2 hours to a customer site, parked for an hour or so, then drove another hour to my kid's college, parked, then drove 3 hours back home.
A mile from home, I stopped to fill up the tank. Car would not start when I went to leave.
Dealer replaced the battery under warranty and said the battery had a bad cell.
Old Sep 24, 2009 | 05:52 PM
subbuzz's Avatar
07 tl-s in
(may seem retarded) is your car in park? when my batt went I at least got a click,click......
Old Sep 25, 2009 | 05:11 AM
baldyxp's Avatar
^my car is parked for a majority of 6-10 hrs a day. But when I do go start it on a regular it starts. But on the day it didn't start was weird cause none of the dash lights came on when you put the key in the ignition.
I don't know what's going on but if it happens again I'm definitely gonna take it into the dealer. But who thinks I should take it in regardless it only happened one time?
Old Sep 25, 2009 | 05:56 AM
Turbonut's Avatar
Take it in and they will do a battery load test and check the system. Don't want to get stranded away from home some night. The battery can go at any time and with no advanced warning.
Old Sep 25, 2009 | 11:04 AM
Bearcat94's Avatar
AZ Community Team
I can vouch for that.
Have it checked. BTW, I think AutoZone, etc will test the battery for free if the Dealer gives you any hassle.
Old Sep 30, 2009 | 04:27 AM
baldyxp's Avatar
Yeah, it was a loose battery terminal. It happened once or twice again, but the first time I checked the battery it didn't seem loose. Today, I went to start the car and it wouldn't start numerous times so I checked the battery. The negative terminal was almost practically off.
obert
Dec 14, 2015 11:36 PM
mc1114
Oct 8, 2015 01:26 AM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
JnC
Sep 11, 2015 06:06 AM
jordanboi
Sep 5, 2015 01:33 AM
