TL-S Battery Dead After 2 Days Sitting
Old Sep 3, 2007 | 09:42 AM
camporealer's Avatar
Unhappy TL-S Battery Dead After 2 Days Sitting
I have seen others have this problem.
I parked my car Friday Night because I took my wife's truck down to Philly. I got back last night. I went to start my car this morning and just got some clicks and dings. I am charging it now, but I don't know if this will fix the problem.
For those who have had this problem, what was the fix?
Only 8,000 miles and I have left the car sitting for longer than this before!!!
Old Sep 3, 2007 | 09:51 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
care for an aftermarket solution, since I am a mod-head
http://www.optimabatteries.com/publi...utomotive.html
retail for a little over hundred, but they are the best
Old Sep 3, 2007 | 10:25 AM
ezland00's Avatar
did you leave the light(s) on?
If the battery won't charge. take it back to the dealer, it should be under warranty. My battery die on me at 25k.
My Q
How long does an average battery last?
Old Sep 3, 2007 | 10:31 AM
Turbonut's Avatar
Originally Posted by ezland00
My Q
I've had a bettery die in 4 months as it was defective, and a battery that is in one of my cars that sees maybe 4,000 per year is 14 1/2 years old, as it was installed in May 1993. Both extremes, but can't see why a quality battery woudn't last 4 to 5 years.
Old Sep 3, 2007 | 10:40 AM
ggesq's Avatar
The battery in my 05 died w/in the first 12 months of ownership. Dealer replaced the battery. There was a TSB for the batteries for the 05 MY. There was also a TSB for the Navi draining the battery. Luckily for me, it wasn't a problem w/ the Navi but a defective battery. Get the dealer to give you a new battery.
Old Sep 3, 2007 | 10:42 AM
Turbonut's Avatar
Ran out of time, but as it's new have the dealer check battery and draw. If was older I'd suggect checking draw by removing the neg terminal and checking with a meter.
Old Sep 3, 2007 | 11:12 AM
JAB00's Avatar
Unless you didn't leave a light on by mistake it must be a defective battery. I'd take it to the dealer for a diagnostic and probable replacement. I've had my 05 for a little over 2yrs w/o any battery problems (23K miles).
Old Sep 3, 2007 | 11:15 AM
KeithL's Avatar
Have dealer check the bluetooth components, several , inclduing my friend has had battery die due to bluetooth not properly going into sleep mode.
Old Sep 3, 2007 | 11:18 AM
coykiam's Avatar
since it died in the first year of ownership.....did the dealer replace it under warranty or did you have to pay ???
Old Sep 3, 2007 | 11:31 AM
It started up after a brief charge. I have been using it today and started it several times.
I didn't leave any lights on. I will have the dealer check out the electronics and the battery.
thanks for the input.
Old Sep 3, 2007 | 11:36 AM
ggesq's Avatar
The dealer replaced it under warranty.
Old Sep 3, 2007 | 01:19 PM
SouthernBoy's Avatar
Registered Member
Any chance your outside temperature display was showing flatlines? This happened to my '04 manual TL seven weeks after purchase and 36 hours before leaving for my vacation. Battery was totally dead after sitting for 4 days. I charged it up and went on my vacation and have never had the problem since then.
If you get flatlines on your temp display, there is a good chance that the ECU will remain in an error loop even with the ignition off (this bug may have been fixed in later models).
Check the voltage of your battery after the car has been sitting for around 3 hours. You should show in the neighborhood of 12.8 volts with a healthy battery.
Old Sep 3, 2007 | 01:21 PM
ballinfizzle89's Avatar
FizzyStatus!
My battery died at 18k miles..take it to the dealer, theyll replace it for free
Old Sep 3, 2007 | 05:38 PM
amaupin's Avatar
I am on my third battery on my 07 TL-S. The original battery died at the dealership while I was buying the car. Very nice... The second battery died after the car sat for a week while I was travelling. I just returned from a week vacation, and it was fine. Maybe a bad batch of batteries?
My car as less than 3K miles, so dealership replaced under warranty.
Old Sep 3, 2007 | 08:12 PM
TL-AFYD's Avatar
so this is what i have to look forward to huh?
Old Sep 4, 2007 | 04:47 PM
love2cul8r's Avatar
2007 TL-S CBP/ES 6MT
i wonder what's going on with this battery issue! my aunt has an MDX and her battery was also dead after 1 year! her dealership refused to replace the battery - which was obnoxious seeing as her car was well within the warranty period. also, she tried using the Acura TLC service who made her wait 3+ hours for a jump so that she could at least get her car home! That's ridiculous in and of itself! I've read other posts about the crappy TLC service... I for one, would forego TLC and call on AAA who I've always had fast, friendly service.
Old Sep 6, 2007 | 03:09 PM
whashburn's Avatar
Keeping the headlight switch in "AUTO" position
I recall reading in my 07 Type-S book that it is recommended that if the car will sit for more than one week at a time to *not* keep the headlight switch in the AUTO position.
This struck me as odd because that would suggest the system consumes a considerable about of power when idle and the ignition is off. I wonder if there is a different reason for the suggestion to be in the book?
Old Sep 6, 2007 | 04:09 PM
coykiam's Avatar
Thanx for the head up guys....my car just turned a year old and have been on the look out for signs of weak battery..lol...hopefully it'll die while its on the drive way and during its warranty period.
Old Sep 7, 2007 | 08:22 AM
Calebz's Avatar
I guess this explains why every time I have my 04 at the dealer for anything they load test the battery. Always thought that was a little weird, but my dealer is pretty cool, so I didn't give it any thought
Old Sep 12, 2007 | 11:13 PM
weeeerd's Avatar
We've seen it on a few cars. The control unit for the bluetooth is staying on.
Old Sep 13, 2007 | 09:33 AM
REY's Avatar
REY
Its been my experience that honda/acura batteries not so good. I just had the battery die on my 04 tl while I was sitting in the car with the lights on changing out the cabin air filter. I know the dealer will cover it without charge in my case but I just went to a parts store and bought the best thing they had. I would prefer not to get stuck you know. I had 2 batteries replaced once in a brand new 06 honda odyssey back to back and I have heard others complain about the same thing. Its almost as if they think all the battery ever needs to do is crank the engine, and thats all it should be able to do.
Good Luck
Old Sep 14, 2007 | 08:11 AM
94 DC4 RS LSV/Turbo
did everyone ignore my post..
and aren't you supposed to unplug the bettery anyways if you are leaving the car for a while...
TLDude876
Dec 28, 2016 03:18 PM
mugen_kid
Nov 13, 2015 10:38 PM
adreano17
Sep 16, 2015 02:54 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
jordanboi
Sep 5, 2015 01:33 AM
