Strange no start issue
Old Apr 5, 2016 | 11:18 AM
dipset97's Avatar
Alright everybody, just picked up a 2005 TL, 6 speed with 130k on it. Got a pretty good deal after looking for about a year. So I bring it home Friday night, park it, go back out to start it, and nothing, doesn't crank at all. Got the starter checked, ended up being fine. Alternator checked, fine. Battery was a little low, but wasn't bad, so I put it on a charge and it fired right up. All the way up until yesterday, it'd decide when it wanted to start and when it didn't, so I cleaned the negative and positive terminals on the battery, and ever since then I've had zero luck. Put it on jumper cables, and that doesn't seem to be doing the trick either. The immobilizer seems to be fine, none of the keys make a difference either. I was thinking main relay, but nothing else seems to being going wrong with it. Any suggestions on what it could be?
Old Apr 29, 2016 | 11:34 AM
SixSpeedLuxury's Avatar
3rd Gear
Did you ever get this resolved?
Old Apr 29, 2016 | 12:20 PM
^are you having a similar issue?
if so, please describe whats happening with yours.
as all cases are different!
Old May 1, 2016 | 10:01 AM
Agentphan007's Avatar
Try to push start it. If the car fires up the starter is toast.
Old May 4, 2016 | 08:24 AM
maharajamd's Avatar
I'm going to bump this unresolved issue thread instead of creating a new one.
Occasionally, maybe 1 out of 10 times, when I go to start the car I turn the key and everything shuts down. Like the battery is completely dead. The car unlocked, all the lights worked, accessory worked, but I turn the key and nothing. So I pop the hood, disconnect the battery for a second, reconnect, get in the car and it starts right up.
I've found that it's less prone to do this if I turn the key while the gas gauge is "going up". If that makes sense. If I turn on accessory and let everything "load up" it happens 1 time out of 5...or 4.
Old May 4, 2016 | 09:22 AM
^odd.
Old May 4, 2016 | 09:43 AM
maharajamd's Avatar
And I have no idea where to even start looking.
Old May 4, 2016 | 10:07 AM
^dump it for the S5.
Old May 4, 2016 | 10:12 AM
maharajamd's Avatar
That's what I'm trying to do!
mada51589
Jan 9, 2025 04:40 PM
ericcdong
Apr 1, 2016 08:58 AM
Rdxlim
Mar 17, 2016 06:07 PM
Larry1030
Mar 11, 2016 08:27 PM
achavez20
Mar 4, 2016 02:09 AM
