Starter not cranking
Old May 25, 2011 | 11:34 PM
guitarplayer16's Avatar
Hey guys
Just having a little trouble with my TL.
I tried starting the car but for some reason, the starter doesn't crank but you can hear electrical noises outside the car and the only thing I observe is the DRL stay on(as usual on canadian tl after startup), but the interior lighting such as the map lights flicker when I hold the key to try to crank the starter.
The battery is brand new oem one purchased about a month ago, so that is probably out of the question.
I'd like my car to startup lol thanks!
Old May 26, 2011 | 07:33 AM
johnny3's Avatar
Sounds like the battery or cable connectons, make sure they are clean & tight, try jump starting it. Since you just changed the battery makes me think you may have gotten a bad battery,
Old May 26, 2011 | 07:50 AM
TLin401's Avatar
'13 Hyundai Sonata
Make sure the terminals are tight. Also just because you have an OEM battery doesnt mean anything. From what I have read on here, OEM batteries are the worst and that is why MANY people go aftermarket.
Old May 26, 2011 | 05:34 PM
It's strange because the Starter doesn't crank, but everything has good power still.
It shouldn't be my battery.
Sure, there are peoples Oem battery dying in like 5 months, but I only replied mine a few weeks ago...
I will check the connections.
Thanks guys
Old May 26, 2011 | 06:17 PM
Here's a video showing what's wrong.
Video #2: Interior map light dimming when my car is in "on" position, and me just rolling up my window. Notice how the light dims when I push on the button (you can hear clicks in the video).
If it is indeed my battery, I'm expecting to get a no charge replacement from my Acura dealer =)
Old May 26, 2011 | 06:19 PM
nfnsquared's Avatar
Thanks guys
Yeah, remove and clean the connections, even if they look good. Then re-tighten them (make sure you have navi/radio codes).
If that doesn't work, try jumping it and go to autoparts store and get battery tested.
Could also be your starter. A fair amount of 04 starters are starting to fail....
Old May 26, 2011 | 06:21 PM
SpiderX1016's Avatar
I'd recheck for loose connections.
Old May 26, 2011 | 06:24 PM
Thanks for the reply nfnsquared!
I will clean them, and reconnect them.
Then I'll jump the car and see if it will work.
I hope you saw the videos above to help you assist me.
I replaced my 04 starter already last year =(
https://acurazine.com/forums/showpos...2&postcount=11
Old May 26, 2011 | 06:34 PM
tek_cru's Avatar
I'm guessing its fuel pump (if not the battery).. similar symptoms happend to my old car.
Old May 26, 2011 | 06:52 PM
nfnsquared's Avatar
If the FP was bad, the car would still crank...
OP, saw the vids. Bad connections would do that...
Old May 26, 2011 | 07:09 PM
Jesstzn's Avatar
Thanks guys
I bet its the negative connection either at the battery or the other end. The small draw electrical will work but the starter is a big draw and needs a good ground.
BTW I have an 06 still on the OEM battery ...
Old May 26, 2011 | 07:11 PM
You're the best man.
Could it be my accord fog wiring connections, or is it strictly just the terminal connection?
Thanks!
Anywho, I'll try to clean the connectors to see.
It could be! Maybe it's because I wired my accord fogs ground to the ground the negative wire goes to?
Thanks for the suggestions guys and I will try it all, as it is raining right now (you can see in my vids).
Old May 26, 2011 | 08:55 PM
Thanks!
It's either connection at the battery or starter. Most likely battery because you recently changed it.
The fogs shouldn't affect it even if you used the same bolt for ground.
Old May 27, 2011 | 06:25 AM
Thanks man.
I should also note, when I try to start the car, I hear a small buzzing noise on my left by the "vsa, mirror buttons".
Old May 27, 2011 | 06:51 PM
Just cleaned the battery terminals, and no luck!
This is depressing =(
Old May 27, 2011 | 08:02 PM
vanhan's Avatar
6th Gear
Sounds like you have starter problems. If you can get at it check for constant power on the heavy line going into the solenoid. And also check the light wire going to the small terminal for power during cranking. Could be it... its relay controlled by the PCM
Mike Pilipenko
Mar 26, 2024 09:21 PM
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
agupta3224
Sep 22, 2015 08:08 PM
