Really gonna need some direction.
Old Oct 19, 2020 | 11:16 AM
furiousstylez's Avatar
Hello and thanks all. I will try to keep it short to to the point. Bout a year ago had a major malfunction on cyl 3. Coil melted on plug,plug broke off inside head. Had a guy my buddy knows put a head on it. He also replaced an injector on that cylinder. Don't know exactly what caused it but it ran fine afterwards. Every so often I was getting catalyst efficiency low and 02 sensor code. Did the spark plug non fouler trick which bought me some time. Fast forward to a couple weeks ago. Found the engine was using oil and about same time noticed smoke from the exhaust. Ordered valve seals and a bunch of other stuff but I was too late. Driving home from work last week and it started shuddering and felt like I lost the tranny. Starts right up, misfires at idle, will move, but it will only roll down the street and thats it. Wot does nothing at all.
Old Oct 19, 2020 | 11:34 AM
Really sorry 05 tl w/145k
Old Oct 19, 2020 | 12:14 PM
csmeance's Avatar
sounds like the trans might be toast, but check the fluid level and see the color of the fluid, it should be pinkish red. If it's brown then it's burnt.
Old Oct 19, 2020 | 12:19 PM
StealthTL-S's Avatar
08 TL type-S
Sorry man, i'm hoping your TL is not dead....2008 TL-S , manual , 200,000 miles....
Old Oct 19, 2020 | 07:56 PM
Kind of had that thought but if its cold and I start it up and take off it will take off but once down the street it bogs all the way down to almost nothing, barely idling. ts really weird. Whats a test i can do to ensure its the tranny and eliminate everything else.
Old Oct 19, 2020 | 08:55 PM
Jackass's Avatar
The engine idles and revs just fine when in Park or Neutral? A misfire and a failed transmission really don't go together. You were not clear about it does nothing at WOT. Does the engine rev and the car goes nowhere? Or you go WOT and the engine doesn't respond?
My assumption here is that WOT and the engine doesn't respond....as in you have a clogged cat or something to that extent.
Old Oct 20, 2020 | 09:49 PM
Yes thats exactly right but on first startup the engine will rev up in park though it feels about 20% power. When I attempted to move it before the tow truck showed up and it moved alright for a lil while but after a couple hundred feet. Then wot and the engine wouldn't respond at all and the car wouldn't move.
Old Oct 20, 2020 | 09:54 PM
I Don't believe its the tranny. I got it with 120k and have drain and filled twice. Engine oil if fine. I'm thinking with the previous damage to the cat from prior incidents and the oil leaks from the valve seals currently ruined the cat.
Tony Pac
6G TLX (2021+)
3061
Jul 8, 2025 08:51 AM
Louka
Oct 26, 2020 12:11 PM
maknwar
Sep 28, 2020 12:09 PM
Kwokadoodled
Mar 24, 2011 08:28 PM
earthbound741
May 29, 2008 09:30 PM
