P0389 after timing belt replacement
Old 09-25-2011, 08:24 PM
jackfrost56's Avatar
2004 TL 150,000 miles.
I replaced the timing belt due to age, replaced idler pully, water pump, and timing belt tensioner. All was good for one day. The next day I drove it and the check engine light was on as well as VSA light flashing. I pulled codes and it gave me P0389 Crank shaft position sensor B circuit intermittent. What would cause the code?
Old 09-27-2011, 01:48 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Don't tell me you unpluged the CSP sensor during replacement.
Old 09-27-2011, 01:51 PM
Majofo's Avatar
The connection is shown at the bottom left. If you unbolted this assembly / unplugged the connector, you dun goofed.
Old 09-27-2011, 08:57 PM
Thanks for the input but no the crank sensor was never unpluged and the crank sensor pid is still reading when i look at the engine sensors on the scan tool.
Old 05-24-2018, 12:29 AM
A.Rod310's Avatar
I have the same problem on my 2004 Acura MDX with that damn check engine light for P0389 after Timing Belt replacement
what did you do to fix that P0389 Problem on your Acura
Old 06-28-2018, 01:16 AM
Hyperblu's Avatar
Do a crank relearn with a high end scan tool. If your belt was past the service limit stretch, that code will pop up when it is replaced as the ECU is now having to retard the timing.
Old 05-07-2019, 02:50 PM
Mrthree1zero's Avatar
I'm having the same issue after timing belt replacement.
Did you ever figure out the issue?
Old 12-05-2019, 05:53 PM
UA6-MT's Avatar
I got a p0389 too except it wasn't right after a timing belt replacement. A day after the code popped up, the car stalled and it appears that the belt might've broke. I too want to know because it could help me diagnose my problem.
merc009
09-14-2015 06:43 PM
iCrap
09-11-2015 06:21 PM
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: P0389 after timing belt replacement
