Need help triangle light check engine light and vsa light
Old Sep 3, 2019 | 08:51 AM
Michael Solano's Avatar
I have a 2006 acura TLV Tech automatic the car was running smooth 0 problems I slow down on the freeway to do something and I sped up to get my regular speed up to 65 miles per hour on my trip after I did that my car slowly started losing power the check engine night popped on Triangle light turned on and the VSA light is on as well when I pushed the button for the VSA nothing happens even if I hold itI've already unplug the battery for a full day and reconnected it lights are still there I've looked for open hoses or anything everything looks clear nothing looks badd I popped in my OBB to scanner and I got a couple Codess p2101 p2176 pd p2101pd p2277pd I looked them all up But I don't think any of these Coats could be the problem the car still drives but it won't go past 30 miles per hour if I go uphill will start slowing down but it will maintain 25 to 30 miles per hour Has anyone had this problem before or if you have a YouTube video please drop it in here please
Old Sep 3, 2019 | 09:15 AM
Jackass's Avatar
I can't read that ramble. Please try to use at least some punctuation. Just from the codes you put in, it sounds like the APP sensor or the throttle actuator (don't know its real name) is having issues.
Corey3189
Feb 23, 2018 11:29 AM
Beezuskurk
2G CL Problems & Fixes
Jun 29, 2015 03:33 PM
mr.b
Jun 26, 2011 03:25 PM
wakipaki
Jul 5, 2009 02:30 PM
GaddAMIT
May 28, 2004 03:28 PM
