Huge Intermittent ac problem and knowledge Acura mechanic?
Old Oct 18, 2015 | 06:38 PM
trailmix211's Avatar
7th Gear
I'm having a huge problem with my ac, the ac is acting up, only works intermittently. What I've do so far new compressor, Evap and purge system twice, change relay, new micu multiplex. Okay so Here's the weird thing, when I turn on my headlights the dash won't dim, and the headlight symbol doesn't light up. But when it dims and the headlight symbol comes on the ac will start working. Ran dtc codes. I'm thinking it's the gauge control module but is there a way to check? Please help. Willing to pay who can help me trouble shoot the problem. Thanks in advance.
Old Oct 18, 2015 | 07:17 PM
polish_pat's Avatar
do wipers and horn work when dash wont dim? Check if anything else doesnt work when the dash doesnt dim, radio, seat heaters, seat adjustment, mirror adjustment, or anything else that you might control from cabin. I'm asking because i've had a similar issue on my Jetta, just wanted to see if we had anything in common
Old Oct 18, 2015 | 07:46 PM
csmeance's Avatar
did you do the HVAC test to see if you can get it to spit out a code on the temp display?
Old Oct 18, 2015 | 11:22 PM
01acls's Avatar
:gheywave: $$$$$$$$$$$$$$$$$$$$$$$
Old Oct 29, 2015 | 07:41 PM
7th Gear
Yes everything else works.
Old Oct 29, 2015 | 07:42 PM
7th Gear
What's the hvac test? How is it performed?
Old Oct 29, 2015 | 07:45 PM
7th Gear
Okay I'll give that a shot thanks
Old Oct 29, 2015 | 07:49 PM
01acls's Avatar
You can lead a horse to water but you can't make'em drink.
Old Oct 29, 2015 | 07:55 PM
7th Gear
So I tried that and the aircon display didn't come up. I've been using this to run my dtc codes.
Old Oct 29, 2015 | 09:09 PM
MonkeyTrucker's Avatar
Life Connoisseur
Really long quote
jroca
Oct 22, 2015 11:11 AM
brent byers
Oct 21, 2015 10:00 AM
OfdSaints
Oct 19, 2015 07:26 AM
stizzylita
1G TSX Problems & Fixes
Oct 15, 2015 02:28 PM
loweredCL
Oct 15, 2015 02:26 PM
