Which torque converter, please help
Old Oct 30, 2015 | 10:40 AM
tangodown305's Avatar
8th Gear
i am swapping out my 06 acura tl transmission. i was able to find a 07 accord 3.0 transmission. which TC do i get, the one for the accord will not line up to the flex plate on the TL. Or can i reuse my TL TC? please help.
Old Oct 30, 2015 | 03:09 PM
flyromeo3's Avatar
I would get a TL torque converter
Since both bell housings are identical ( im only saying that because the accord trans fits the TL block ) I would go with the TL torque converter. OR, what about getting an accord flexplate and keep the accord Torque converter?
Have you measured the input splines on both transmissions? Does your TL torque converter fit into the accord trans. Meaning just put it on for testing purposes.
Old Oct 30, 2015 | 05:52 PM
8th Gear
The 07 accord TC that came with the transmission is the same as the my TL TC, well bolt pattern wise. The bolt pattern to the flex plate is 11.250". The TC I ordered from autozone (07 accord v6 baya trans) has a bolt pattern of 10.250".
No, I haven't measured it. I gave the (accord) core to autozone. I did place the TL TC into the accord trans and it fit perfectly. Also i had a friend look the TC for both cars and he said they have the same part #. I wanted to see if any one else could verify that, and why was the TC from autozone so off?
tatertot3381
Nov 1, 2015 04:09 PM
cipdagr3at
Oct 29, 2015 12:37 PM
sockr1
Oct 28, 2015 04:10 PM
polish_pat
Oct 28, 2015 07:51 AM
Oct 27, 2015 04:44 PM
