engine light blinking video included
Old Nov 3, 2009 | 08:31 PM
sebas809's Avatar
Exclamation engine light blinking video included
so after installing my injen CAI I was messing around with the car and decided to make a little video of it..... when I later watched the video I noticed that the engine light blinked 3 times, is this normal?
here is the video http://s8.photobucket.com/albums/a6/...91102-0025.flv
Old Nov 3, 2009 | 10:29 PM
friesm2000's Avatar
B A N N E D
how long did you wait for the computer to relearn after the intake install, cause a blinking check engine light normally means that the computer sees that the cat is in intiment (spelling???) danger/damage and goes into protect mode
the computer should have logged it in memory, so get it checked
Old Nov 4, 2009 | 12:48 AM
dechlin's Avatar
the check engine light blinks when the engine is skipping
Old Nov 4, 2009 | 03:36 PM
AckTL05's Avatar
Former Sponsor
blinking light means catastrophic error and could result in failure. Get to a place that reads codes. Or buy an obd2 sensor like me, it comes in handy a lot.
Old Nov 4, 2009 | 03:38 PM
AckTL05's Avatar
Former Sponsor
check spark plugs and such.
hotgrease's Avatar
2004 AM TL
so do you have to do anything after installing a CAI other than just drive the car? reset the ECU perhaps?
Old Nov 4, 2009 | 04:01 PM
friesm2000's Avatar
B A N N E D
take it easy for a while and as you let the computer relearn you can give it more throttle
what part of denver you from???
Old Nov 4, 2009 | 04:37 PM
SatinSilverAV6's Avatar
2003 Accord Coupe V6
your engine is misfiring!!
Old Nov 4, 2009 | 05:02 PM
friesm2000's Avatar
B A N N E D
geneally caused by \/ (misfiring)
Old Nov 4, 2009 | 09:06 PM
hotgrease's Avatar
2004 AM TL
Another CO member! I'm in SE Denver near Alameda and Colorado. What about you?
Old Nov 4, 2009 | 09:14 PM
friesm2000's Avatar
B A N N E D
sheriden and 36, also try https://acurazine.com/forums/rocky-mountains-316/, we just had a meet last month and 9 cars showed up
btw: to many members down south
Old Nov 4, 2009 | 11:27 PM
sebas809's Avatar
I drove the car for about an hour with the intake installed before taking that video..... ill try making another video at the same speed and see if it happens again... what could cause the misfire? the car has 60 000 miles the spark plugs should be ok although I do plan on changing them soon
Old Nov 5, 2009 | 11:21 AM
Majofo's Avatar
It probably just an emissions code.. could be a misfire, or AF ratio is too lean / rich especially with high RPM's & a new intake. Don't worry about it.. it's not catastrophic as it was suggested.
Old Nov 5, 2009 | 02:43 PM
friesm2000's Avatar
B A N N E D
it could take a couple hundard miles before everything is fully relearned
Old Nov 5, 2009 | 10:17 PM
sebas809's Avatar
ok I wont worry about it but ill keep an eye out for it, thanx guys
Old Nov 5, 2009 | 10:20 PM
friesm2000's Avatar
B A N N E D
and a code should have been logged in memory, cause the light did come on, even if it was only 3 blinks
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
