Code p1077
Old Aug 25, 2017 | 06:48 PM
06nycTL's Avatar
Code p1077
P1077 INTAKE MANIFOLD RUNNER CONTROL SYSTEM MALFUCTION (low rpm). Anyone have experience with this code?? At first I thought is may of been a hiccup so I cleared it, came back earlier this week took a look at the imrc tightened up the throttle cable a bit. It was fine for 2 days and now it's back again.. just wondering if there is anything else I can do before replacing the irmc unit .. the check engine light seems to turn on at start up but I don't notice a difference in how it starts or how the car drives
Old Aug 26, 2017 | 12:51 AM
jimmyfu's Avatar
Not sure if this helps bu t i had the code P1078 - Intake Manifold Runner Control System Malfunction High RPM. I thought I had to change out the unit, so I ordered the part without even inspecting it. Funny thing, this code only popped if I hit 4000 RPM. If I never touched it, it never popped up. Upon arrival of the new unit, I finally took a look at the unit and then saw that the connection was just loose. Pushed the plug back in and worked without needing any change.
I'm not sure if you'll be so lucky, but check the connections first to see if they're all set. I just did a google search for P1077 and at least for the RSXs, it looks like it's a fairly common issue and usually the culprit is a sticking solenoid, which needs replacing. Good luck!
Old May 9, 2021 | 05:30 PM
Gantert12's Avatar
3rd Gear
mom having the same engine code pop up, have you found the solution? It happened after I changed my valve cover gaskets.. everything still runs fine though. Just an annoying light on and want it gone
Old May 9, 2021 | 07:29 PM
peter6's Avatar
There is an actuator on the intake. Either you didn't connect it or you somehow got the flaps stuck.
jimmyfu
May 8, 2023 10:55 AM
delta2873
Apr 26, 2012 08:09 AM
saucy
2G TSX Problems & Fixes
May 23, 2011 10:33 AM
cls
Oct 24, 2001 12:11 AM
skyline518
Oct 8, 2001 10:47 AM
