Bank 2 Sensor 1 wiring connection(by the radiator)
Old May 10, 2021 | 02:09 PM
A.Sensation's Avatar
Hello all. I have a 2005 Acura TL and it’s spitting out codes for the Bank 2 Sensor 1. I just replaced the o2 sensor with new Denso ones thinking it’s the sensor. While taking out the old o2 sensor, I noticed that the wiring connection point was covered in oil. Which I presume has been there before I changed the Valve Cover gaskets. Well I cleaned it up with a microfiber shop rag the best I could and connected the new sensor but it was still showing the codes for no activity. Is there a way to cut off the wiring connection(female-end) and replace it with a pigtail? I couldn’t find pigtails for the 5 pin connectors(upstream) anywhere on Google, correct me if I’m wrong. What would be the best alternative?
could I cut off the connector, do a full clean inside and out then splice the wires back to the connector?
Old May 10, 2021 | 02:33 PM
^ If there are no visible breaks in the wiring, hose the female end connector down with this stuff before you go cutting.
Amazon.com: CRC 05103 QD Electronic Cleaner -11 Wt Oz: Sports & Outdoors Amazon.com: CRC 05103 QD Electronic Cleaner -11 Wt Oz: Sports & Outdoors
Old May 10, 2021 | 05:11 PM
Didn’t think about spraying it down with some sort of electric cleaner. Thanks for looking out✊
canucklehead2004
Nov 19, 2017 03:58 PM
rp23
May 15, 2017 01:17 AM
LazLong
Jun 16, 2015 01:32 PM
CLsurfer
1G CL Problems & Fixes
Jul 9, 2007 12:57 PM
em17henry
Jan 7, 2005 01:12 AM
