Clock not working - which fuse to disconnect?
Old Oct 10, 2021 | 07:00 PM
dpace32's Avatar
Lightbulb Clock not working - which fuse to disconnect?
Hello - I have a minor issue with my 2005 TL that is driving me NUTS: the clock above the factory navigation screen is NOT accurate by several hours. I tried looking for ways to set it in the navigation menus but I the menu options refuse to adjust the time. Whenever I disconnect my car battery (which I just did to replace the battery), the clock resets to 1PM. My strategy to fix this might seem simple: which FUSE under the steering wheel powers the clock? What I would like to do is disconnect the user until 1PM and then plug it in. Ideally I would do this without disconnecting the battery all together.
Please stop the insanity and help me fix this issue:
Old Oct 10, 2021 | 07:38 PM
If you have the 'glove box' owners manual, look at the index in the rear under 'fuse' and some info should be there.
Old Oct 10, 2021 | 09:34 PM
Pair of TLs's Avatar
May as well wait for DST to end next month...
Old Oct 10, 2021 | 09:48 PM
Curious3GTL's Avatar
I don't know if there's a fuse but the trick is to connect the battery at 1:00 on the dot.
Old Oct 11, 2021 | 06:51 AM
dpace32's Avatar
I tried the radio fuse - no luck. open for more ideas... would like to do it from the fuse to make it easy and avoid messing with the battery every 6 months for DST
Old Oct 11, 2021 | 01:22 PM
dpace32's Avatar
Still can't find it... if it helps here is a link with all the options: https://fuse-box.info/acura/acura-tl...004-2008-fuses
Old Oct 11, 2021 | 02:12 PM
TheSauceBoss's Avatar
I ran into this same issue a few months ago, where you can no longer use the nav buttons to change the clock. I do not recall there being a confirmed fix to the issue, it may simply be a hardware failure related to the age of the car.
I still have hope, considering the "minute" side continues to keep time, it's just the hour side thats like 6 hours off for me.
Old Oct 11, 2021 | 03:08 PM
dpace32's Avatar
Weird same here - started a few months ago... Same here where the hour / minute moves just way off and resets to 1:00 when battery is disconnected.
Old Oct 11, 2021 | 05:06 PM
my car's clock is off as well, about 6 hours off.
happened a few months ago as well
Old Oct 11, 2021 | 05:07 PM
most likely a satellite or software bug, a la Y2K
Old Oct 11, 2021 | 06:15 PM
dpace32's Avatar
FOUND THE FUSE !!!! For those with navigation on the 05 Acura TL the fuse is #7 (which is labeled "backup"). This controls the clock along with navigation, power locks, etc. if you pull the fuse you can always plug it back in at 1:00 to get the clock to reset
Old Oct 11, 2021 | 08:58 PM
Talking AM or PM
Be sure to set your alarm so you don't miss the one-minute window!
Old Oct 11, 2021 | 09:33 PM
dpace32's Avatar
What do you mean? Lock the doors before pulling the fuse?
Old Oct 11, 2021 | 10:28 PM
peter6's Avatar
He meant to put your alarm on the phone / alarm clock so you don't miss the 1pm / 1am, or you will need to try again in 12 hours.
Old Oct 12, 2021 | 06:50 AM
dpace32's Avatar
Lol
Old Oct 20, 2021 | 03:41 AM
comkb's Avatar
they say its a bug in the navigation, something how they never programmed it for 2021. dont expect acura to give out free navigation updates.
Old Oct 22, 2021 | 07:11 AM
DMZ's Avatar
DMZ
Head a da Family
Haven't you been following all the nearly endless posts on here about the clock issue with the '04/5/6 Nav? Disconnect and connect all the fuses you want.
It's a bug that Acura will NEVER fix. The ONLY real solution is to upgrade to the '07/8 Nav system by replacing the Nav DVD unit and screen. I did it, and have never looked back! These items can be found on ebaY.
Old Oct 22, 2021 | 10:56 AM
pohljm's Avatar
twice a year you will need to pull the fuse or disconnect battery at the correct time in order to have the clock be accurate, Or tear apart the dash and spend hundreds. your choice
Old Nov 9, 2021 | 12:13 PM
dpace32's Avatar
It's that time of year - pulling that magic fuse and putting it back in worked. Love it.
Old Nov 15, 2021 | 10:30 PM
yosh415's Avatar
thank you for the advice, it worked for me too
Old Dec 11, 2021 | 02:26 PM
Arafel's Avatar
Fuse trick worked
Thanks to everyone who figured out the fuse trick. Did it today and worked like a charm. Still thinking of doing the 2007 nav upgrade, but for now I can sit tight and spend $$ on Xmas stuff.
Old Feb 16, 2022 | 09:14 AM
Jon Brennan's Avatar
I have an 08 TL type-s and am having the same issue with my clock. I bought the most recent Nav DVD update from Acura and it fixed nothing. I'm gonna try the fuse trick because this clock issue is driving me crazy lol.
Old Aug 26, 2022 | 01:45 AM
Breakz360's Avatar
After a while after reset, the clock on my 05 TL reverts to the correct time, just an hour behind. The minutes are correct but like stuck in daylight savings time or another time zone. Like the time is stored in memory somehow, and will fix itself just an hour behind. So weird
alfadoctor
Jan 9, 2024 11:55 PM
tvarghese
Nov 4, 2022 08:01 AM
snoopgecko94
2G TSX Problems & Fixes
Nov 7, 2020 06:56 PM
BARRACUDAMOTORS
Jul 4, 2010 06:11 PM
msmching
Jun 13, 2009 11:43 AM
