Check engine p2422
Old Oct 25, 2020 | 07:30 PM
hugoboss7's Avatar
Check engine p2422
I bought a 2007 Acura TL automatic not too long ago. The check engine light is on and the code is reading p2422 EVAP CVS valve stuck closed.
i did a bunch of research and can’t find a fix. I changed the purge valve sensor under the hood.
I went under the car and took off the vapor canister,
checked everything. Changed the pressure valve sensor that was on the vapor canister. The only thing I haven’t tried was replacing the shutoff valve filter and the entire vapor canister. I want to save some bucks and do it myself but I’m running out of options and might have to take it to a specialist.
If anyone has gone threw the same problem, I would appreciate some feed back.
Old Oct 25, 2020 | 10:47 PM
peter6's Avatar
Do you have a scan tool that can view live data? You need to view the tank pressure sensor readings. No idea if generic obd scanners allow that.
If you can view that, I can guide you through some checking.
If not replace the vent valve.
Confusing part is that vent valve is for some reason called "Dust filter". Additionally if you order brand new canister, it comes without the vent valve.
It is more or less cube, snaps in into the canister, has two vacuum ports and electrical connector.
It should be normally open, so if you try to blow into it, it should allow. Give it power and it should close.
If you want to test if first, be careful as moving / tapping it might get it to open and then "pass" the blowing test.
https://www.oemacuraparts.com/oem-pa...9tYXRpYw%3D%3D
I wouldn't get it from amazon, just posting so you can see the picture.
Amazon Amazon
You can get used one from junkyard for ~$50 that probably works.
Also make sure that your canister didn't fall apart and charcoal didn't get into the lines.
Old Oct 25, 2020 | 11:33 PM
hugoboss7's Avatar
I went with the oem parts I’ll update when I get and install parts
Old Oct 25, 2020 | 11:34 PM
hugoboss7's Avatar
Lightbulb
https://www.amazon.com/Genuine-Honda...ustomerReviews
thanks man
Old Oct 26, 2020 | 04:47 PM
hugoboss7's Avatar
P2422 If i drive
I have to drive 35* miles tomorrow for work. Is it bad to drive if my CEL is reading p2422??
it’s a evap CVS valve closed shut. I think there might be some blockage in the tubes. Waiting for parts to fix the problem.
Wanted to know everyone’s thoughts on if I should drive it or not
hugoboss7's Avatar
45-60 miles sorry
Old Oct 26, 2020 | 05:31 PM
ttribe's Avatar
Year, make and model of car?
Old Oct 26, 2020 | 05:33 PM
hugoboss7's Avatar
2007 Acura TL
Old Oct 26, 2020 | 05:37 PM
ttribe's Avatar
MODERATOR NOTE: Thread moved to model specific forum.
Old Oct 26, 2020 | 05:39 PM
peter6's Avatar
You could have asked in the other thread about same code.
Yes it's fine. Usually EVAP codes don't do any harm to the engine / rest of the car.
(unless purge valve is stuck open)
Old Oct 26, 2020 | 05:41 PM
good call
Merged
Old Oct 26, 2020 | 05:49 PM
hugoboss7's Avatar
sorry Im new haha didn’t know
Old Nov 15, 2020 | 01:39 PM
hugoboss7's Avatar
Light still on
So a while ago I installed a new canister and a new dust filter along with all new tubes. Check engine light is still on. Still reading p2422. Am I suppose to unplug the battery and restart the car or is there another problem that can be pulling that code?
Old Nov 15, 2020 | 06:03 PM
csmeance's Avatar
get a code reader from amazon (bluetooth ones are fine too) and clear the code. If it comes back you have an issue from the wires coming from the evap unit you've replaced.
Old Feb 20, 2024 | 08:13 PM
MrBlue's Avatar
This web page wont let me upload an MP4 vid showing my Scan tool stats on the EVAP sensor.
Old Feb 20, 2024 | 09:39 PM
upload to youtube.
Old Feb 21, 2024 | 01:28 PM
MrBlue's Avatar
Uploaded Vid
EVAP CVS on Dust Filter is OPEN as I checked it when I replaced the FTP Sensor.
BTW: this has also triggered a Code 77-01 (Functional Abnormalities of the Fuel Emissions or Auto Transmission) & disabled my SH-AWD
DaIll1
1G RDX (2007-2012)
Oct 27, 2020 10:45 AM
lbrasi293
Mar 26, 2007 09:42 PM
CLpwner
1G CL Problems & Fixes
Mar 11, 2007 09:26 AM
Doni1
Aug 3, 2006 02:59 PM
namesake
May 23, 2004 10:19 AM
