Chattering sound after side motor mount replacement
Hey guys/gals.
I did some research (on here actually) and went with some Ebay mounts (kit) and recently did the right side mount because it's the easiest and it's cold out. I did it because I was getting a horrible clunk over bumps which is now gone which is great. However, I'm getting a new noise that's pretty annoying. Around 2500RPM there's a chattering sound, which I can only assume is this new mount, now I'm not sure if it's because it's a cheap mount or what. It almost sounds like the mount bracket is loose, but it's not.
- I installed and tightened the mount bolts with the motor jacked up - same noise
- I installed and tightened the mount bolts with the motor down - same noise
Ossman14
Aug 31, 2018 08:41 AM
paperboy42190
Jun 4, 2011 07:18 PM
dasuddith33
2G CL Problems & Fixes
Nov 20, 2008 12:08 PM
BLACKURA_NY
Dec 5, 2007 05:15 PM
