Engine Vibration after new front Motor mount and right side mount
Old Nov 19, 2008 | 12:42 PM
dasuddith33's Avatar
Airborne MP 16th Unit
Exclamation Engine Vibration after new front Motor mount and right side mount
Since i put the new mount on the sound has gotten worse.
i checked everything nothing is loose, rear motor mount is fine...
i have to check the rear tranny mount ... so what i be hearing when i'm driving or turning any direction not driving hard @ all , crusing @ 60-90 the noise will not stop any ideas
Old Nov 19, 2008 | 12:45 PM
fuzzy02CLS's Avatar
Which mounts? stock or IM? If they are stock did you make sure to re hook up the vacuum lines?
Old Nov 19, 2008 | 12:56 PM
Stock mount yup and vacuum lines are in .... anyother Ideas i open to anything this real annoying
Old Nov 19, 2008 | 03:13 PM
anybody HELP!!!!!
Old Nov 19, 2008 | 08:51 PM
djarovsky's Avatar
The mounts may be binding after the installation, thus transferring noise and vibration. Try neutralizing the engine mounts. These steps are taken from various Acura Service News articles:
• Loosen the mounting bolts until they are finger tight
• Start the engine, set the parking brake, apply the service brakes and then shift from Drive to Reverse and Reverse to Drive several times
• Shift to Park, shut the engine OFF, then torque the mounting bolts to specification.
Old Nov 20, 2008 | 09:46 AM
thanx I'm goin to try that After work ...
Old Nov 20, 2008 | 11:06 AM
fuzzy02CLS's Avatar
Why didn't you replace the rear? Maybe that's bad? I would say something isn't tq'd, or lined up right.
Or there's another bad mount that's now more apparent cause it's working with 2 new mounts.
Old Nov 20, 2008 | 12:08 PM
already did the back one the rear motor mount was changed out all bolts tight for the rear one though
Feb 25, 2020 09:57 AM
drone619
Jan 26, 2016 07:09 PM
wilztlxs
Dec 1, 2015 09:16 AM
08 NBP TL
Sep 8, 2015 08:49 PM
Desert Ridge
Sep 5, 2015 09:47 AM
