Blower motor issues
Old Jan 22, 2021 | 04:05 PM
kpayne111's Avatar
Blower motor issues
I'm having an issue where my blower motor doesn't work intermittently. I find anything below full fan speed it really doesn't want to work, and if I give below the glove box a smack, it turns on, but not much fan speed until medium-high setting, and it blows plenty of air on high. I tried replacing the transistor and this didn't really fix the problem. It seems like there's a loose connection somewhere, but the connectors and wires under the glove box seem fine. Anyone run into a similar problem before?
Old Jan 22, 2021 | 07:21 PM
csmeance's Avatar
sounds like a blend door motor is stuck and sending air in the wrong vents all the time...
Old Jan 22, 2021 | 09:47 PM
peter6's Avatar
Can you hear motor running all the time, or is it completely quiet?
If it's completely quiet and smacking it makes it run, big chances are that blower motor itself is bad (or rather brushes are worn out).
Old Jan 23, 2021 | 11:40 AM
Ted Kief's Avatar
Most likley the motor is going bad but check the connectors on the resistor and motor as they often burn and cause a intermittent connection
Georgiey22
Oct 12, 2021 11:02 PM
peter1984
Feb 27, 2020 09:08 AM
swake457
Oct 12, 2012 03:41 PM
blackdog
Apr 13, 2008 06:56 PM
