Help with p0344 code after 3.7 swap
3.7 swap and I’m getting a p0344 code timing is new every seal was replaced when the car is warm I would turn it off and then when I start it up it misfires but if I have it revved to 1500k rpm it will stop misfiring and vsa light and the p0344 will stay on and it won’t go pass 3k rpm any suggestions
Check the three bullet points, under 'Cause:', on the link below?
P0344 - Acura Diagnostic Trouble Code (DTC) Definition, Causes and Diagnosis (dtcdecode.com)
