Advice on replacing an engine
Old May 31, 2023 | 06:49 PM
Ækolyn's Avatar
Hey everyone. I just graduated from college and was looking for a car, and came across the opportunity to get a 2006 TL with a manual transmission. The timing belt is broken however. I was wondering what you all would recommend, particularly about sources for an engine.
Additionally, can an engine from an automatic work in a manual?
Old May 31, 2023 | 07:30 PM
csmeance's Avatar
You can use any 2004-2006 3.2L J32A3 engine and it will be a direct bolt up to your car.
OR
you can go with a J35A6 and try to get some more power:
https://acurazine.com/forums/3g-tl-2...cklist-999988/
and
https://acurazine.com/forums/3g-tl-2...ngine-1002904/
Old May 31, 2023 | 10:55 PM
joe.abp's Avatar
Unless you have confirmed that the valves made contact with the pistons, I wouldn't knock out the engine just yet. Ericthecarguy on youtube had a timing belt obliterate itself while on a highway. He ended up putting on a new belt and it ran just fine. You could try that, if it ends up not working out you can use the new timing belt on the 2nd engine.
Old Jun 1, 2023 | 04:15 PM
Ækolyn's Avatar
I have not confirmed if the valves have made contact with the pistons. Is there a good way to check that? Or would it be better to replace the belt first and see if that fixes it?
Old Jun 2, 2023 | 08:28 PM
Pair of TLs's Avatar
Put on a new belt and time it. Then hand-rotate the crank several times and see if there's interference.
Old Jun 9, 2023 | 07:29 PM
Chad05TL's Avatar
Unless you get an engine plus the TL for less than what a running 2007/8 TL would cost , then I would just find another TL. Because your time is worth something .. The 2007/8 have some upgrades that you'll probably want
Old Jul 3, 2023 | 05:58 PM
bbsitum's Avatar
Happened to me past year at my 03 tl. Get gamble, replaced timing belt only and all was good.
quistrat
May 12, 2020 06:38 PM
TL88
Mar 6, 2019 08:30 PM
LiveFrom323
Dec 8, 2017 02:36 PM
erik2510
Nov 19, 2012 03:13 PM
SkillOBskilled
Jul 25, 2007 12:52 PM
