3rd & 4th switches
Rather then start a new thread..........
Maybe I can get some help??? I've search for 45 mins for Sport Shift or Tiptronic issues, problems, down shift,ect...
My problem... Sporadic problems using SS mode, It just doesn't want to down shift when I ask it to. She works fine in both settings if I let the tranny do her thing. I have replaced the 3rd and 4th switches and keep fresh fluid in her.
Is there a micro-switch or something similar that needs replaced?
Usually they don't go bad, what happened is the clutch material gets in there and clogged up the switches. You can get the switch out and clean it up with some cleaner and blow it out with air once in a while and it should be good.
Anyone else tried this ...?
That's not what happens at all. The diaphragm hardens up over time, throwing the calibration way off. Nothing to do with plugging up. My bad switches were perfectly clean yet way out of spec.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
