2005 TL Positive battery terminal end
Old Mar 31, 2018 | 02:28 PM
Hitlayers's Avatar
Hey guys, my son has a 2005 TL, was changing the battery when taking off the positive battery terminal end, it was so rusted it snapped off, now I need to know is it simple to just buy a terminal end replacement ($6), or is it much deeper than that, just asking because years ago my wife had a 2001 pathfinder and it was not as easy as just replacing the terminal end due to it having a bypass, he needs this car for school and I would like to be able to fix it for him as quick as possible, if I have to bypass the bypass, please let me know how this can be done (miss this site btw)
Old Mar 31, 2018 | 05:23 PM
Jackass's Avatar
Pretty sure there are some on here that used a generic replacement end from the parts store with varying degrees of success/failure. My vote....go order the replacement cable and replace the entire thing. Not something I would want to futz with over the years with another failure. If I am remembering correctly, the entire cable was around $80 or so. Mine failed several years ago as well and I had the dealer replace it.
Old Mar 31, 2018 | 07:36 PM
Joecop67's Avatar
I replaced my positive cable end with a clamp that I bought at autozone.
Old Apr 1, 2018 | 08:21 AM
Hitlayers's Avatar
Thanks for responses guys, looking to go the quick and cheap route right now, will replace the entire piece at a later date, @joecop67, that is what I purchased, was it as simple as clipping and attaching?
Old Apr 1, 2018 | 10:53 AM
Joecop67's Avatar
Yes it was. I may purchase a whole new positive cable because when I stripped back some of the insulation on the cable, it looked to be filled with corrosion.
So next time I have an issue I’m going to swap the cable out.
https://www.acuraoemparts.com/oem-pa...BlZWQtbWFudWFs
Old Apr 1, 2018 | 01:20 PM
Jackass's Avatar
$42...wow...I must be thinking of a completely different trip to the dealer.
Old Apr 1, 2018 | 06:19 PM
Hitlayers's Avatar
Got it, thanks for the info, just didn't want to run into an issue where when I put the new clamp on it does not start
Old Apr 1, 2018 | 06:26 PM
Hitlayers's Avatar
Also one last thing, I still have the old clamp on, but the bolt part is the piece that broke off, instead of cutting it off, can I just buy a small hose clamp from home depot, wrap the clamp that is on there and just tighten it, would that work also?
Old Apr 1, 2018 | 07:40 PM
Joecop67's Avatar
I don't know. I pried open the old clamp and put to new clamp on. I didn't want to cut it, that would have shortened the cable.
Old Apr 2, 2018 | 02:22 PM
Hitlayers's Avatar
Sorry for my ignorance, sounds good, how did you do that, because that's the position i'm in, would rather not cut it
Old Apr 2, 2018 | 02:26 PM
Joecop67's Avatar
Flat crappy screwdriver. Hammer, etc. whatever it took. Lol.
Old Apr 2, 2018 | 02:38 PM
Hitlayers's Avatar
Nice! Thanks
Old Apr 3, 2018 | 05:25 PM
Pair of TLs's Avatar
Smile 'Xacly!
Couple o' bucks & you're down the road for a long time..Happy motoring! [img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAIAAAC QkWg2AAACjklEQVQokXWSW0jTcQCFf08+SdCTL1KUaESQZV7AF x0hW4HLKMZW3ptKDHWbU1M3nTrDC142NfWh7OI0deo0N6+kjZQ 0ZV6m29r+/3kptZZdREUzO70YkuDHefzO0zmE/I/N/tEw1K6uT39cK3nV2WSac5DjoOhPPS9vDbf4zL8OWX7PpUbvDLe xVHkXM4QM09zCUdtqnpro9tukbmNfBGQAmdiTYiNrdyl9pIsrj vM0GEYObZpetgwFYCMWyNnekQGqf6ne+S7HVoFxMCEp5tysiTo oGAfYcHKBnNLyUEIIk3kJaAKa2Wx/QkhxXig2izqf8ZL5gYQQQlHUZ2Mw/giAsrAwH0KIi4sr0AZ0nnA9SQi5dv0yUGc2pMqS/GZmLMQ02bKzcAMQAiW/95RVVeE0rQS6Ad3SYm2lKvrXXh3waHVKVlPI7mitJ6N9ov0VHi ABioGnQAegBdqADkAH9AIaoMZpym2siSp9GE/e6CTbNAdIoyiJ1ZoDNAKNQAugAVoB7aypYMWWu25WvKiOUJYIy MS7VsfoVUBseBvt5XkK0AANgBpoAlqBrjMe7rPDksVJuTIvtFu rJh9si31q711HNKCIivHl84OAJqAd0AIaDi9QnMDAZmV/c6I0MWBu3k4IIfWVzHE9Y3/tPpAvFAX6+nsIU1jJIpbPlbPZohBsVRgHU1WKm7IU5sEOdmq1M NN9pIv1wxoPyH8uiLvVPF3D3W+WTKwXjvUKa4s5gsgLNvvK4dj TM2ZxnNtzld+YnucYT1i3iNZMKcZBQfuTyNy04FiO19T0/NE72emvcmn4Pa5bVtL5UnlQkZQh5Htz2aezH0RQDuexn7XTTr2 +p6JcUVGW398/YKe/HBH+Agd9l87TGIe4AAAAAElFTkSuQmCCAA==[/img]
silverTL6
Sep 28, 2017 08:31 AM
imakeholesinu
Oct 3, 2012 10:07 AM
Doc Holliday
18
Sep 27, 2005 03:12 PM
UNCTYPE-S
Feb 7, 2005 10:37 AM
