TL stroker help
Old Apr 2, 2018 | 05:05 PM
81brettkeith's Avatar
TL stroker help
I have a 06 TL with a 3.2 Block in it a 3.7 crank rods Pistons car stop running now pulling it apart I can spend the crankshaft bolt and the camshaft don't move timing belt looks to be in place any ideas what to check next
Old Apr 2, 2018 | 05:10 PM
horseshoez's Avatar
Latent car nut
Can you please rephrase, I'm having a difficult time figuring out what you're asking.
Old Apr 2, 2018 | 05:25 PM
I have a 06 TL with a 3.2 Block in it a 3.7 crank,rods,pistons. Car stop running while driving just sputtered to a halt would not restart. Pulling it apart now got the camshaft covers off and while I spin the crank by hand the cams and sprockets do not move but the belt looks to be in place also the keyway in the Kranks still in place what else would cause the bottom end to be able to be turned and the top end not spinning?
​​​​​​​ thank you for your help
Old Apr 2, 2018 | 06:22 PM
Ron A's Avatar
Administrator
I deleted the thread you posted in the Third Generation TL (2004-2008) > 3G TL Performance Parts & Modifications Forum since you already have this thread and that is not the proper forum for this topic.
Old Apr 2, 2018 | 06:46 PM
O.k....
so where might that be or do you not help just inform me i am incorrectly using site?
Old Apr 2, 2018 | 07:32 PM
horseshoez's Avatar
Latent car nut
I'm guessing the tensioner failed. When you turn the crank does the timing belt move?
Old Apr 2, 2018 | 10:23 PM
No it doesnt
no
Old Apr 3, 2018 | 07:32 AM
horseshoez's Avatar
Latent car nut
no
​​​​​​​So either the tensioner or the timing belt has failed.
Old Apr 3, 2018 | 11:56 PM
I took my timing belt cover off and directly around with a crankshaft gear the belt is paper thin and shredded into a Rat's Nest.think im gonna have to replace some valves.
bigjohnson
May 7, 2018 03:11 PM
tenzingsherpa
Sep 2, 2010 10:05 AM
vashuba311
Aug 13, 2003 09:08 AM
