07 TL-S No Electrical Power
Old Oct 24, 2018 | 01:32 AM
syn11's Avatar
Hey what’s up guys. Hopefully someone can help. I got in my car the other day and everything came on as usual. When I turned the ignition. Everything shut off. I was like wtf. Removed the key and did it again and same thing happened. Lights came on and everything shut off. After this there has been no power at all.
I then proceeded and have done the following:
Battery was replaced like 2 months ago. I changed the battery just in case with a buddy’s battery and nothing. I checked the main fuse and it’s good. I even changed it just to double check and nothing. I check the voltage and it’s good. I check the voltage on the fuse box and it’s good. I checked all the fuses. Under the hood and inside the car. The grounds also look good. I even tried changing the ignition switch and nothing. I did take the whole hood fuse box out to make sure it wasn’t corroded underneath and it looked good. Now a weird thing did happen. When I put it back on the lights in the car came back on. When I gave it ignition it shut everything off again. I took it off again and connected it and it made no difference the second time around. Then I checked all wires on the fuse box one by one and they all seem fine and not loose or anything. I also checked for power at the starter and there is power there too.
Cant figure it out. Anybody wanna chime in?
Old Oct 24, 2018 | 01:57 AM
MyGuti's Avatar
check to see if your battery terminals are corroded.
also, do you hear any clicking when trying to start the car?
Old Oct 24, 2018 | 02:11 AM
syn11's Avatar
They’re not corroded. I actually just replaced the terminals a month ago. And there’s no power whatsoever. So no clicking sounds. No lights come on. No nothing. It’s as if I never paid my light bill. Lol
Old Oct 24, 2018 | 02:25 AM
MyGuti's Avatar
that's really weird. and you've already swapped the ignition switch and verified starter works.....
that's the end of my help lol
Old Oct 24, 2018 | 02:29 AM
syn11's Avatar
Lol yeah man. Sucks. I even disconnected my amp and some other miscellaneous things I had connected to ensure it wasn’t causing a short of some kind. Shit has me going crazy.
Old Oct 24, 2018 | 03:06 AM
MyGuti's Avatar
is your HFL module unplugged?
Old Oct 24, 2018 | 08:05 AM
syn11's Avatar
That dinosaur is extinct. Lol. Yeah I’ve been had that removed a long time ago.
Old Oct 24, 2018 | 08:10 AM
Jackass's Avatar
Once you turn the key and the car goes dead:
- What does it take to get the car alive again?
- Even your dome light goes dead?
- Does the dome light turn back on when you remove the key?
- Once dead, have you checked voltage at all of those test points again?
My bet is your battery cable has internal damage. Wiggle it around and things will probably come back to life.
Old Oct 24, 2018 | 08:39 AM
syn11's Avatar
The car never comes back to life. It stays playing dead. Lol. But seriously no electrical power at all. It’s as if I removed the battery from the car. The lights don’t come back on at all. I’ve tested them with the voltmeter and they have power which is what makes it even stranger. I’ve wiggled those cables like There’s no tomorrow.
Old Oct 24, 2018 | 10:59 AM
Jackass's Avatar
Good luck on this one.....sounds like you have covered the obvious already. When you test voltage, where are you touching for ground? At the battery? Or just chassis? The fact that the entire car goes dead should lead you back to the battery cables. Nothing else should make the entire car play dead.
Old Oct 24, 2018 | 11:00 AM
what voltage was it reading?
It could by the ignition switch needing replacement.
Old Oct 24, 2018 | 09:23 PM
syn11's Avatar
I've tried it from both ends. I just did it again to make sure and now I’m getting different results. When I put it to the ground of the battery and the positive of the battery it reads 12.6. But when I put the ground on the chassis it gives me 2.70.
Old Oct 24, 2018 | 09:25 PM
syn11's Avatar
12.6 from the battery posts and 2.7 from chassis ground and positive from the battery or fuse box. I’ve tried 2 different ignition switches that are brand new.
Old Oct 24, 2018 | 10:28 PM
redbeard1's Avatar
What do you get from battery negative post to chassis ground?
My understanding is that you should be getting the same reading from [positive battery post to chassis ground - you got 2.7 you should get 12.6] as [positive battery post to negative battery post - 12.6]. The fact you don't makes me think you have corrosion/loose wire between negative battery post and chassis.
Old Oct 24, 2018 | 10:31 PM
syn11's Avatar
And you are correct. Lol the negative wire was the culprit. It looked perfectly fine. After that finding I tried another wire and voila. We have power!!! Thanks for the help. Now she’s back. Yeayyyyy!!! Never judge a book by its cover is the lesson learned today kids.
Old Oct 24, 2018 | 11:25 PM
redbeard1's Avatar
Glad it's working again.
Old Oct 25, 2018 | 12:13 AM
syn11's Avatar
glad it's working again.
eleventure
Sep 22, 2013 11:16 AM
Midwest
Jul 7, 2010 11:37 PM
Zeroskillet
May 15, 2009 02:33 PM
blkaspec
Apr 27, 2009 02:22 PM
3.2intheATL
Jan 2, 2007 09:46 AM
