where to find replacement O-ring for AEM CAI
Old Mar 16, 2009 | 05:02 PM
tonester's Avatar
I was under the hood of my TL this weekend and noticed the o-ring that is between the hex-head nut and the inlet pipe of my CAI has been crushed and damaged. Does anyone know where I can get a replacement O-ring? I've contacted AEM about it but hasn't heard back from them.
thanks
Old Mar 16, 2009 | 07:41 PM
jweb12's Avatar
Don't know the exact size but you could probably find a good match at a hardware store in the plumbing department (look in the sink/shower washer area). The o-ring that comes with the kit, at least in my case, doesn't fit that well to begin with. If you tighten the bolt down snug, the o-ring basically pops out. I ended up just barely snugging the bolt in there until the o-ring starts to push out. Also used a little teflon tape around the threads near the head of the bolt.
Old Mar 17, 2009 | 05:39 AM
chill_dog's Avatar
Oderint dum metuant.
The o-ring did suck; mine disintigrated a long time ago. I never replaced it. I simply tightened the bolt down some more and everything has been fine since.
Old Mar 17, 2009 | 12:28 PM
jptl04's Avatar
Bone stock tl-s
i lost mine during my install, went to the hardware store like jweb said found a perfect replacement. no problem
Old Mar 17, 2009 | 12:43 PM
mglax13's Avatar
New shoes on my
M12 2mm o-ring. Teflon tape instead should be fine.
Old Mar 20, 2009 | 10:40 PM
AcuraTLG3's Avatar
I crushed mine pretty good during install...just called AEM and they sent me out a new one at no charge. The instructions on tightening those down are pretty weak, everyone over tightens and they end up destroying it....I think I even asked them to send me out two, pretty sure they did.
Old Mar 24, 2009 | 12:24 PM
tonester's Avatar
thanks for the info guys. mine was a little crushed when i first installed it, now it just broke apart over time.
Old Mar 28, 2009 | 06:17 PM
Jesstzn's Avatar
Thats what I did ... a bunch of wraps of teflon tape and snug it down.
cycdaniel
Dec 17, 2019 10:58 AM
spidermankb
Mar 5, 2019 11:34 AM
Abe_Froman
Sep 16, 2015 01:27 PM
iCrap
Sep 11, 2015 06:21 PM
gqdabien
Sep 8, 2015 11:41 PM
