S/C ACM knock sensor problem CEL
Old Nov 11, 2009 | 04:17 PM
AckTL05's Avatar
Former Sponsor
Cool S/C ACM knock sensor problem CEL
So I did what everyone else says to "fix" the cel problem and I put the red/green wire back to stock and erased the CEL light. The problem is that I feel a bit of a difference and am worried I chose the wrong wires because the damn CEL came right back on with "knock sensor bank 1". I am wondering if I chose the wrong wires or if something is wrong and I am not picking up on it. Also, do I leave the two wires that were unneeded from the ACM or connect them together to create a loop. PLEASE HELP...
Old Nov 11, 2009 | 04:28 PM
bmeyer's Avatar
I called CT and they said to disconnect the knock tap from the ACM. The guy I talked to said that the unit was originally designed to filter out the signal, but some cars are just extra sensitive.
Hooking it back up to the ECM directly will still allow the ECM to manage any knock.
Old Nov 11, 2009 | 04:30 PM
AckTL05's Avatar
Former Sponsor
Took apart the two wires that were cuircuiting the ACM red/green wire and put the red/green wire back to the TL reg Green wire. So now I have two wires from the ACM not being used which were connected to the red greens but the check engines still on.
Old Nov 11, 2009 | 04:32 PM
bmeyer's Avatar
Reset the ECM?
Old Nov 11, 2009 | 04:33 PM
AckTL05's Avatar
Former Sponsor
I resetted the CEL light if thats what you mean. Then the light came right back on. Those are the wires that I use right?
Old Nov 11, 2009 | 04:35 PM
bmeyer's Avatar
I mean disconnect the batter, leave it sit for 10-20 minutes and go through the whole idle reset procedure outlined in the manual.
Old Nov 11, 2009 | 04:36 PM
AckTL05's Avatar
Former Sponsor
Well Those are the right wires right I am not going crazy? I am fine to drive it becuase its dark out now and I need to go somewhere later. I did this correctly?
Old Nov 11, 2009 | 04:39 PM
bmeyer's Avatar
It's B-6. Says it's Red/Blue
Old Nov 11, 2009 | 04:41 PM
AckTL05's Avatar
Former Sponsor
you know what the green/red does?
Old Nov 11, 2009 | 04:44 PM
bmeyer's Avatar
green/red is the MAP. red/blue is the knock
Old Nov 11, 2009 | 04:51 PM
AckTL05's Avatar
Former Sponsor
oooooooooh - wow that other forum is telling people the wrong thing. You know this for sure or did you read it somewheres?
Old Nov 11, 2009 | 04:52 PM
bmeyer's Avatar
It's right in the manual. I'd recommend you pick-up a copy.
Old Nov 11, 2009 | 04:55 PM
AckTL05's Avatar
Former Sponsor
The owners manual? Oh, im technological illiterate. Thanks a lot, and hows the HBP?
Old Nov 11, 2009 | 05:14 PM
ussi's Avatar
I (don't) whine.
Yeah, the write-up on here was wrong when i did mine. Use the wires according to the service manual.
I think this is the thread I referred to: https://acurazine.com/forums/showthr...r+knock+sensor, but from what i remember it wasn't the red/green but the red/blue...i think.
Old Nov 11, 2009 | 06:03 PM
AckTL05's Avatar
Former Sponsor
well good thing I checked because I was going to make myself work extra hard for nothing.
Old Nov 28, 2010 | 07:18 PM
NSXCessive's Avatar
Hi guys I just installed my Comptech S/C and I'm getting the same Knock Sensor code. Can we clarify its the Red/Blue wires for knock need to be removed from the ACM and NOT the Red/Green wires?
Old Nov 28, 2010 | 09:47 PM
c2pid's Avatar
red/blue. the wire that goes to pin b6 (as per comptech's installation diagram).
Old Nov 29, 2010 | 02:16 AM
NSXCessive's Avatar
Excellent thanks for verifying, I also checked the service manual after I posted and verified that its B6 red/blue. Based on the service manual:
Terminal # 6: RED/BLU KS (KNOCK SENSOR) Detects knock sensor sional With enoine knock ino : pulses
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
cycdaniel
Dec 17, 2019 10:58 AM
NJALLDAY57
Oct 13, 2015 08:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
