My 3.7 mani, ZDX TB, and pnp runners build thread
Old 12-03-2012, 11:22 PM
  #281
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
I think there will be a difference in the flow characteristics of the ZDX manifold and the TL manifold....think the ZDX should gain a little more in low end TQ
Old 12-04-2012, 02:14 AM
  #282
Green Machine
t0talacuratl's Avatar
Originally Posted by anx1300c
t0talacuratl, any ideas why you didn't gain much power? I was thinking maybe it was because you had a ported stock manifold, but so did Sonnick.
I was thinking the same. I guess my PnP stock IM flow that well. I had it done thru Moores Performance, and definitely felt a difference after install. Unfortunately I wasn't able to Dyno then. Like I mention before I'm still satisfied with the swap.
Old 12-04-2012, 03:19 AM
  #283
DomGSR-T's Avatar
Originally Posted by Euro-R_Spec_TSX
OK, after reading this thread I got motivated to pick up the J37 manifold. After looking over the parts illustrations I decided to take a chance on the ZDX manifold. Just got it today and it looks just like the TL manifold but unpainted. So I saved a few bucks, but I think I would have preferred the TL manifold! Anyway, just wanted to post up in case anyone else doesn't care so much about looks. And yes, it is magnesium.
Sorry to hijack here but I have a question, If I open my intake in two to polish the inside if the manifild by removing all the 14 bolts surrounding the intake, what kind of sealant should I use to seal them up?
hondazex (12-11-2012)
Old 12-04-2012, 07:39 AM
  #284
swoosh's Avatar
^^^ the manifold is sealed by some kind of glue...you can try to take it apart but it will be a lot of effort....it will definitely create a ton of mess....I did go at it with a mallet and screw driver and no luck...
Old 12-04-2012, 07:45 AM
  #285
anx1300c's Avatar
You're not going to gain anything by just polishing the insides of these manifolds. They're already as smooth as can be.
Old 12-04-2012, 08:04 AM
  #286
swoosh's Avatar
^^^ the human heart and mind always wants more
Old 12-04-2012, 08:06 AM
  #287
thisaznboi88's Avatar
use hondabond to reseal it. But I don't think it will be easy to open and even harder to reseal
Old 12-04-2012, 01:58 PM
  #288
All motor
Sonnick's Avatar
I'm sure opening up the individual runners inside the manifold would help, but who knows. I do know that my manifold was done by P2R and that only the opening and lower ports were ported; nothing else. The opening is 68mm and the lower ports are I believe 1mm larger than stock. Internally, the manifold is stock. I believe Moore's Performance goes a step further and ports the inside as well, but I could be wrong.
Still strange that total didn't gain anything, considering he has the TB too. Idk.
Old 12-04-2012, 05:00 PM
  #289
DomGSR-T's Avatar
Exactly, until I have seen it for myself, I will believe there's some imperfections in it Maybe if the ''glue'' is heated it will get soft and easy to remove? like putting front light casing in the oven to change the lens?
Old 12-04-2012, 05:38 PM
  #290
anx1300c's Avatar
Maybe the 3.7 TB isn't giving any more power than a bored 3.2 TB at 66/71 mm or even a completely stock 3.2 TB (doubtful). Maybe Moore's did a really good job on Total's and that's why he only picked up a few hp, or the few hp he did pick up came from the larger TB alone.
Best bet on the stock 3.2 manifold is to just cut the top open, port it and then have it re-welded. I'd like to see a stock Maxbored TB and stock intake done this way vs the 3.7 setup on a flow bench, side by side.
Sonnick (12-05-2012)
Old 12-04-2012, 06:19 PM
  #291
NvrDwn's Avatar
Type in ( Dual Throttle Bodies for DBW ) it should be the first fews that come up on google. It's on . Read look at the pics and enjoy
Old 12-04-2012, 10:30 PM
  #292
DomGSR-T's Avatar
This is exactly what I want to do next spring/summer. stock TL-S mani with bored zdx TB vs tl-sawd mani and bored zdx TB. I'll do this with another member here on a same morning dyno. We will also test the V2 vs a custom 4'' CAI.
Old 12-04-2012, 10:48 PM
  #293
anx1300c's Avatar
I've been following that loosely. Looks like a pretty sick setup.
Sounds good. I think you'll need the P2R adapter for the TL-S manifold? And you'll likely need to open up the mouth on the TL-S manifold to 71-72. Not sure what it measures stock. I know my 3.2 manifold was ~ 65-66 mm at the opening; just slightly larger than the stock 64mm TB.
Old 12-05-2012, 01:46 AM
  #294
DomGSR-T's Avatar
Yes i'll have to get the P2R adapter and will open up the opening size of the manifold and the P2R adapter to match the new TB size.
Old 12-05-2012, 08:06 PM
  #295
Brock
Euro-R_Spec_TSX's Avatar
The flow should be the same as they are the same casting. The ZDX has a plastic cover over the intake, so it doesn't need to look pretty.
Old 12-06-2012, 09:25 AM
  #296
anx1300c's Avatar
Has anyone tried removing the butterflies in the 3.7 manifold?
Old 12-06-2012, 09:51 AM
  #297
Green Machine
I wouldn't be surprised that Moore really did a great job. Like I said, I noticed a big difference right away after install. I did not have my TB or runner port matched either. Moore Performance just made sure the IM match the stock openings. However I plan on going back to the dyno soon; got a new part in that might see much better results....cough...cough...exhaust...cough!
Old 12-06-2012, 11:00 AM
  #298
All motor
Sonnick's Avatar
^ You were still on the stock exhaust? Ahem...that could have been part of it.
Anx: A member of v*6*p removed his butterflies. There was no before/after, but I'm assuming the same principle applies.
Old 12-06-2012, 11:07 AM
  #299
anx1300c's Avatar
Sonnick, what principle is that? Never really researched it much, but recall something about a torque dip somewhere?
I think Total had a modified Greddy cat back if I'm not mistaken.
Old 12-06-2012, 03:43 PM
  #300
All motor
Sonnick's Avatar
^ Yea, there is a dip in torque below 4K RPM. It was substantial on my dyno. Although the manifolds were different, there were only minimal gains under 4K. After 5K is where the manifold really came alive, but I lost 12-15 hp/tq before 4K with the deleted butterflies.
Old 12-06-2012, 05:17 PM
  #301
anx1300c's Avatar
George dropped his pricing on all TB boring.
$99
http://maxbore.com/index.html
The following 4 users liked this post by anx1300c:
Atlas.46 (12-07-2012), hondazex (12-11-2012), Sonnick (12-09-2012), TLove It! (12-06-2012)
Old 12-06-2012, 07:03 PM
  #302
Green Machine
You are correct sir! I had the Greddy piping, but Borla mufflers. It flow better than stock, but wasn't perfect by far.
Old 12-06-2012, 08:30 PM
  #303
All motor
Sonnick's Avatar
^ What exhaust did you end up doing?
Old 12-09-2012, 03:51 PM
  #304
anx1300c's Avatar
Ok, this rev hang is getting fukcing annoying. It only does it under load however. If I'm cruising along in say 6th gear at 60 mph, push in the clutch and rev to any RPM, it drops right back to idle. I've tried this probably 75 times just to confirm...no issues when it's not under load. If, however, I'm accelerating heavily and then shift to the next gear, it'll drop to 4.5k and fluctuate 2 or 3 hundred RPM either way, then drop to 3.5k and do the same thing, then around 2.5k, then down to wherever it should be.
I've reset the ecu twice and then let it idle both times for 15-20 minutes (cold idle is a bit higher than with the stock setup, but once warmed up it's fine)
I've checked all hoses etc.
Unplugged and checked main TB, IAC and MAP connectors. Also switched back to stock MAP sensor.
Re-tightened TB nuts/bolts.
Re-tightened manifold cover bolts.
Next step is to pull cover and make sure the manifold to runner bolts are tight.
Then pull TB off and make sure butterfly is ok.
I just can't wrap my head around the fact it only does it under load, which would logically rule out a standard vacuum leak....maybe.
Also, I'm not getting any codes!
Old 12-10-2012, 10:42 AM
  #305
dandaman15's Avatar
Didn't it do it before the manifold swap? On my stock accord it will not go back to idle, instead it does these steps before it goes to idle. Its supposed to do this on purpose. Say you do a 2nd gear pull push in the clutch when its close to red line. Notice it drop quickly to 4,500 like you say and stay there. then to 3,300 and stay there. These are pre-programmed shift points so when you do a pull like that and want to skip shift to 4th or 5th, you can let the clutch out at these points and it wont wear the clutch at all. It'll be at the exact rpm it needs to be.
Old 12-10-2012, 12:39 PM
  #306
All motor
Sonnick's Avatar
Anx, when you let off the gas, does the car lurch forward as if you had 300 broken motor mounts? Mine does this all the time. If I let off the gas, the nose dives and bounces a few times before leveling out. It's very frustrating. It does this when shifting as well.
My buddy replaced my mounts so it's not that, and my struts aren't blown either. He suggested that it could be because the AFR is so off partial throttle. The car is now seeing SO much more air than previously and without a tune, it can't adjust for partial throttle. So once the gas is let off, there is much more air in the TB than before, so it can't compensate. Could this potentially be a similar problem to a similar cause? What he said made sense to me.
He suggested we try the 09 TL MAP sensor, but you said you switched from the TL sensor to stock and it made no difference?
Old 12-11-2012, 02:13 PM
  #307
gerzand's Avatar
^It had made a world of difference in low speed partial throttle between gear changes for me. No more bucking when trying to shift smoothly from 1st to 2nd.
Old 12-11-2012, 03:13 PM
  #308
swoosh's Avatar
Sonnick, I didnt experience too much of a rev hang with the 05 MAF sensor but every once in a while it would freak out on me....when i went to the SHAWD MAF sensor, it was a very smooth ride....
i almost wanna blame the ZDX TB....all of us are using the SHAWD TB....the ZDX TB/Manifold have different part #'s and am thinking maybe its something to do with wiring
  #309
swoosh's Avatar
Old 12-11-2012, 03:28 PM
  #310
Green Machine
^^Wait is it possible to use the ZDX MAF sensor? I just swap my stock sensor over, but not really experiencing this rev hang that you all are taking about.
Old 12-11-2012, 03:34 PM
  #311
swoosh's Avatar
^^^ I used the SHAWD sensor....I just had to dremel the "guidelines"
here is the pic:
t0talacuratl (12-12-2012)
Old 12-11-2012, 03:46 PM
  #312
Green Machine
^^Ok, so basicly you had to make it fit....so if I do that to the ZDX sensor, it should work?
Old 12-11-2012, 03:54 PM
  #313
swoosh's Avatar
i dont see why it wont
Old 12-11-2012, 06:15 PM
  #314
Green Machine
It seemed hard to plug into; that's why I swapped them. But I'll try tomorrow.
Old 12-11-2012, 07:06 PM
  #315
3gstealth's Avatar
I'm running the zdx TB and sensor with no issues. I did what swoosh did and dremeled off the guidelines. The car runs flawless.
Old 12-11-2012, 08:48 PM
  #316
anx1300c's Avatar
Maybe it did it with the stock setup and I'm going nuts! It makes sense though, keeping the revs up in anticipation of a skipped gear shift. That would explain why it doesn't do it when I'm cruising in 6th, press in the clutch and rev it.
I've gotten that surge very mildly a couple times with the ZDX MAP sensor. Doesn't bother me much.
I think the wiring is all the same from TB to TB; all the same basic functions. I also think the MAP sensors are all the same since all they do is tell the ecu what the manifold absolute pressure is at any given time. I can't see the parameters changing from vehicle to vehicle. It either works or it doesn't, and if it doesn't, it would probably throw a code. I think they're just keyed differently to provide some sort of inventory management and pricing structure. It's a pretty common practice in most industries.
Yep, just file down the plastic ridges like in Swoosh's pic. Won't run any differently though, but at least it's a new sensor. For that reason alone, I'm going to swap the new one back in this week.
Old 12-12-2012, 09:29 AM
  #317
All motor
Sonnick's Avatar
I'm gonna try switching the MAP sensor. If that stops the bucking I will be ecstatic. This sympton occurred prior to the manifold/TB installation, so maybe my MAP sensor was bad? I feel like I would've gotten a code though. Or maybe that could be the P0174 code I'm getting on & off?
I_love_cars: Sup bro? How's your setup doing? We're totally hijacking the sh1t out of your thread....
Old 12-12-2012, 10:11 AM
  #318
swoosh's Avatar
is it the MAP sensor or the MAF sensor? I think the MAF sensor goes in the TB and the MAP would go in the manifold
Old 12-12-2012, 10:56 AM
  #319
anx1300c's Avatar
It's MAP, which is exclusive to speed density systems. Our cars aren't MAF, which I think is part of the reason our cars respond pretty well to intake mods. MAF is pretty finicky when you start adding more air without a tune.
The following 2 users liked this post by anx1300c:
Sonnick (12-12-2012), swoosh (12-12-2012)
Old 12-12-2012, 11:03 AM
  #320
swoosh's Avatar
so I have been writing it wrong though out
Quick Reply: My 3.7 mani, ZDX TB, and pnp runners build thread
