KN_TL's Rebuild/Turbo Install thread
#201
I use the thickest oil I have laying around so it stays on the rings, I put it in a can or bowl and dip the piston in it then stick it right in, the oil ring will hold a lot of oil,
THOSE RODS ARE SWEET I'M JEALOUS
The following 2 users liked this post by UTAH TSX:
KN_TL (01-09-2015),
UTAH Type-S (12-29-2014)
#202
Personally I use a good assembly lube and I am very generous. Also make sure that I prime the the engine and get solid pressure before I start the car. I use just a regular over the counter dino oil and run the motor for 10-15 min bringing it all the way up to temperature while someone else is checking for leaks. I do not let the RPM stay steady in those first 10-15 min but am holding it at 1k for a maybe 20 sec, then up to 1500 for 20 sec then 2000 for 20 sec then back to 1k for 20 sec then up to 2300 for 20 sec then back to 1500. you get the idea. I don't go over 2500 in those first 10 min.
Then ALL oil is drained and filter changed, and I let the motor cool all the way back down. I then use Joe Gibbs break in oil and go break in the motor on the street in about 30 min. I then come home and change the oil again and personally like to run Valvoline Racing oil. Got a lot of good stuff in it and zddp. I run that for the first several thousand miles and then switch to a synthetic.
Works for me.
Works for me.
Fully agreed!
ATF is bad. It was used years ago because people thought it had more detergents than motor oil but that's not the case. It's about 20wt for what it's worth.
I do the same. Some people disagree because it can foul the plugs slightly on startup but I would rather be sure everything is lubed well. Plus, a little boost is a good defouling method lol.
KN_TL (01-09-2015)
#205
With those rods Im thinking 25 LBS some heavy meth injection OOOOHHHH yeah
KN_TL (01-09-2015)
#206
I don't like the idea of the atf.
Here is what I do:
I take a clean lint free rag and soak in ATF. I then go up and down every cylinder after I get back from the machine shop with the atf. I keep doing this until I don't get one spec of dirt on the rag. It usually takes 2-3 passes till I make this happen. I know now that I have gotten all the crap off the cylinder walls, because people think when they get it back from the machine shop its clean and ready to go but usually not.
I then bath the piston and rings in the motor oil I am going to use for start up. I take my hand and apply liberally to the cylinder walls, then once all the piston and rings are assembled I bath them in the oil I am going to use at start up.
Hope that helps
Here is what I do:
Hope that helps
KN_TL (01-09-2015)
#207
Thanks everyone.
The block I have is from the factory and while doing the pressure wash I used scotch brite pads on the cylinder walls with dawn/water then did it again with wd40. I was surprised how much black came off (mixed with the red of my blood from butchering my hands).
After bringing it back inside, wiped it again with 100% IPA lint free wipes and it still came up with lots of black crap. After about 3 wipes per cylinder they were clean.
I've moved on to my heads. Going to clean them all up, knock of the casting marks and lap the valves. Seats and valves look good except for some carbon.
#208
I don't suggest assembly lube on the cam lobes because you can end up with the rocker arm roller sliding on the lobe instead of rolling. Just dump whatever oil you're going to use to fill up the little "pools" of oil in the heads and the lobes will have instant lube when they turn.
I've opened up engines that have sat for a couple years and theres never been a case where the cylinders or cam were lacking oil. The only reason I would take special precaution is because the first strokes are so important for proper break-in.
KN_TL (01-09-2015)
#209
Thanks everyone.
Ironically perfectly smooth cylinders seal better but the honing is necessary with the imperfect machining we have today. I have a feeling the crosshatching is going to get finer and shallower as time goes on.
KN_TL (01-09-2015)
#210
J-series addict
Honda has started using plateau honing on their cylinder along with frictionless rings. Supposedly there is no seating that takes place between the rings and cylinders. This was all done for reduced parasitic energy loss and increased performance. It's just a matter of time before today's standard production engines use performance coatings as seen in race bred engines such as NASCAR and Formula 1.
#211
According to the factory, the block I got was ready to use aside from the cleaning.
What did you do for prep on the shortblock you recently purchased?
#212
J-series addict
i would assume this applies to recent earth dream engines and not a 2006 j32a3 block?
yes, this is correct. Though the j35z and j37a2/4 used low friction oil rings only, their cylinders were not plateau honed like the j35y engines.
according to the factory, the block i got was ready to use aside from the cleaning.
the bare blocks come fully machined but do require cleaning. Though they are machined, i still check all clearances before assembly takes place as a precaution. I've never found an 'out of spec' machined surface in any of the bare blocks i've purchased directly from honda.
what did you do for prep on the shortblock you recently purchased?
the short block assembly's are ready to go motors and though i've never torn one down just to see if its clean, i doubt there would be any concern for it. Tearing down a factory assembled short block would obviously defeat the purpose of the decision to use one instead of building one. That's usually because some customers (or "fellow honda enthusiasts") generally choose a factory assembled short block in hopes of obtaining maximum service life....though i do not necessarily agree. At least with a honda engine anyways. The j35z shortblocks i recently purchased were only done because they were priced ridiculously cheap. And because one of them was used for a fi build, it was prepped simply by opening up the top ring gap a bit more. That's it.
#213
Thanks Robert.
I checked everything before assembly and as you said, everything was perfect.
Is the grease that is applied not an issue? When I saw that your shortblock had the same application as my bare block for I assume rust prevention.
I'm glad I went ahead with a cleaning (by hand). I found lots of stuff not visible to the naked eye.
Heading home tonight, going to re-install the valves into the heads and do some measurements to determine my actual compression ratio after machining and just to know for sure what it is.
#215
J-series addict
Thanks Robert.
Easiest way to clean out a shortblock is by rinsing the cylinders out using acetone or brake cleaner with the deck facing down and whichever cylinder you're targeting at TDC. Then coat them immediately after using regular 30W to keep the machined surfaces protected.
#219
Like I said in my other thread, these came from someone here so I have no idea what happened before I got them. My shop removed 7 thousandths.
I guess I am over the limit but I don't think I am in danger of valve contact based on the fact that ILC milled 40 thousandths off his heads to increase the CR. I'm pretty sure the J32A3 and J32A8 head spec is the same, right?
But now, is there anything I should be concerned with other than valve clearance?
EDIT:
I checked the manual again and it says that the resurface limit is .2mm based on the new spec of 121mm......that's what I based my statement on. It says the new range is 120.95-121.05. At least that's how I read it.
EDIT:
#220
J-series addict
EDIT:
EDIT:
#221
I don't see any concern for valve contact, no. My biggest worry with going over service limit on head resurfacing is strictly with the timing belt in regards to cam pulley synchronization. The more material removed from the head, the closer the cams are to the deck. This means that the distance between the two become slightly closer which will cause the pulleys to no longer be synced during engine operation which COULD require using adjustable camshaft pulleys to correct any unwanted geometry issues. Not saying that this will warrant the adjustable cam pulleys or even throw them out of sync, but you should definitely buy a degree wheel and check camshaft timing after installing the heads just to be safe. You can never be too safe in a forced induction build.
I just came up from looking at things then it dawned on me that these are interference based engines anyway.
So I was just going to see what the implications were and thankfully, you replied.
I'll have to start looking into cam timing a little more closely.
If it does involve adjustable pulleys, do you have any idea who would do something like that?
Thanks again!
#223
Nothing new yet. I'm planning on installing the pistons tomorrow and just ordered a degree wheel and will check TDC next weekend. I'm limited to just doing this on Sat/Sun with the new job taking me out of town during the week. I'm also going to reassemble the heads and get them ready, maybe start that tomorrow as well.
#225
There are no issues with your head milling specs, especially with stock cams. As long as you confirm that your piston meets the stock valve relief position and depth you'll be fine...though you'll probably (and should) clay them anyhow. Go ahead and use the heads though in my general opinion. I DO speak from experience in this regard.
thisaznboi88 (01-11-2015)
#226
Do you know where I can get the stock piston specs for the valve relief.
Also, how do I check the clearance without having to put the whole timing belt system together?
#227
Yes, you'll need to do assembly (no gasket required) to clay.
#229
J-series addict
That's good to know. What mods would be needed?
#230
You would need to remove one and add two triggers points on the cam gear as the j32a3/j35a8 cam sensor uses only three...the j32a2 uses four. There are a total of six spokes on the cam sprockets and if the key way is lined straight up towards the 12 o'clock position, you would need to remove the 12 o'clock point then add a 4 and 8 o'clock points to make it compatible with your ECM.
I didn't do anything else this past weekend except order some stuff to check things more thoroughly and lots of reading so I'll get right on it when I get home on Friday.
Hoping to close on the house soon so I can bring the majority of the engine parts/tools to the new place and be able to work on it during the week.
#238
I have never seen a factory j series belt fail ever even at 200k plus miles and I work at one of the biggest Honda dealers in the country, the only time I have seen them fail is from running out of oil and the cams seize and strip the belt on the crank pulley. or someone changing the belt with aftermarket tensioner and it fails, there is no need to use that pricey belt IMO just get the factory belt not one from a parts store Honda dealer only I have seen to many OE belts bought online, autozone, ETC. that are the junk $20 belts
#239
#240
J-series addict
Don't forget the fact that higher horsepower (specifically forced induction) applications put much more stress on timing belts due to increased chamber pressures. This mechanically translates into a greater force being required to open the intake and exhaust valves. Not that this would REQUIRE the use of a heavy duty timing belt but would definitely reclassify the replacement interval of the belt into a "severe service" category which would be 60,000 miles (normal service is 105,000).
