Intake Resonator Removal REVIEW
Old 09-18-2013, 08:31 AM
  #241
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
I'm here for the John vs Justin cage match!
Old 09-18-2013, 08:41 AM
  #242
Received 16,260 Likes on 11,971 Posts
^its Jon*
Old 09-18-2013, 10:37 AM
  #243
story.customz's Avatar
Does Jon even have a TL?
Old 09-18-2013, 10:39 AM
  #244
^no, he came from subies and then now has an ILX.
Old 09-18-2013, 10:43 AM
  #245
sorry, got confused between big jon and little jon.
Old 09-18-2013, 10:48 AM
  #246
Old 09-18-2013, 10:51 AM
  #247
Jon sounds to me like he knows his stuff, but I agree that his knowledge sounds like it may come from a different platform. I already know Justin knows his stuff...his retention for things he learns amazes me considering how often he walks on the moon.
Old 09-18-2013, 10:54 AM
  #248
Maybe if jon ever comes back he can explain what car he was talking about. I feel like it'll be his ILX
Old 09-18-2013, 10:59 AM
  #249
I'm sure it will...but his logic might be subi driven.
I've been on his thread a bit, he definitely isn't a noob.
Old 09-18-2013, 11:01 AM
  #250
With his description it definitely doesn't seem that way to me either, sounds like he knows his stuff. Just doesn't apply to the design of the TL intake that's all haha
Old 09-18-2013, 11:08 AM
  #251
right, he knows his stuff, but doesnt apply to the ILX or TL.
Old 09-18-2013, 11:14 AM
  #252
Old 09-18-2013, 04:30 PM
  #253
FamilyGuy's Avatar
Originally Posted by usdmJON
...Not only that but the resonator is designed to create velocity while the air travels toward the filter. This creates a suction effect regardless if the engine is pulling or not...
I thought the resonator box was only there to limit the noise? How exactly does it "speed" it up?
Old 09-18-2013, 04:33 PM
  #254
The Boss
Nick216's Avatar
^ Ive seen the inside of the resonator and im wondering the same thing.
Old 09-18-2013, 04:46 PM
  #255
Originally Posted by the world wide web
The resonator in your intake is technically known as a Helmholz resonator, an acoustic device used to control pressure wave harmonics. Air bouncing back out of your engine and into the intake tube doesn't do it in a single pulse the way it would in a single intake runner; the multiple pistons put out pressure waves at their own intervals, and some of those are going to try to bounce back in while others are going out. The result is a "clog" or high pressure area in your intake tube that ultimately limits airflow through almost the entire rpm spectrum.
However, any air tuning is done in the intake manifold and not before it.
this means, you can feed it as much air as you want, the throttle body will be the restriction and will limit how much air will enter.
with the 3.7 shawd manifold and its respected throttle body swap, we've stepped up to a 4 inch intake
Old 09-18-2013, 04:56 PM
  #256
how big is the TB inner bore on the 3.7?
Old 09-18-2013, 05:21 PM
  #257
^bigger than the 3G throttle body
not sure, would have to look up the info in one of the great threads about it
Old 09-18-2013, 06:31 PM
  #258
Pretty sure I didn't ask you if it was bigger or not. I know it is.
What I'm getting at is what part of the slight increase in inner diameter makes you disregard your statement that the TB is the limiting factor and there's nothing extra you can do before air enters it. Is there an inverse relationship that would support that the motor is stifled without a jump to a 4" intake filter/tube now?
Maybe I misunderstood what you're trying to get across. Just cause you're smart doesn't make me dumb, spaceman.
Old 09-19-2013, 08:50 AM
  #259
FamilyGuy's Avatar
Really? Didn't know air was being pushed back out from the engine into the intake. I would've thought something wrong with the valves or their seals if that was happening.
Old 09-19-2013, 08:58 AM
  #260
FamilyGuy's Avatar
I suppose if you put a TB bigger than, say, your intake manifolds/runners, or cylinder intake ports, or air intake system, then it no longer becomes your choke point.
At some point going bigger will yield no benefit, unless you get a bigger engine.
Old 09-19-2013, 09:00 AM
  #261
Justin is on AZ, why u no respond?
Old 09-19-2013, 09:03 AM
  #262
FamilyGuy's Avatar
With the 3.7 shawd manifold and ZDX TB, do we still look for an air intake made for a 04-08 TL or some other model? I suppose it has to be for a TL, in order for it to have the correct bending and length, connections, etc.
Wish we had a list of all these parts and their diameters...3.7 mani, ZDX TB, stock parts, diff air intake system piping diameters such as injen, aem, etc.
Old 09-19-2013, 09:08 AM
  #263
I wasnt trying to insult your intelligence, I didnt know the exact measurement that you're wanting.
it is in fact bigger, on the inlet and outlet.
I believe IHC has done an airflow test to see how much the stock intake and its air filter flows, and determined that the acura engineers did not leave any hp on the table.
meaning, the stock intake and filter outflows the stock throttle body at WOT.
this is why adding a cold air intake does not increase HP tenfold. at best a cold air intake increases hp marginally.
now, when we step up to the 3.7l shawd intake manifold and its respected throttle body, everything is bigger and of course more air is needed.
I was explaining the Helmholtz theory, but "I think" any tuning is done after the intake manifold and it would be best to feed it as much air as needed.
Old 09-19-2013, 09:22 AM
  #264
I'm here for the Jeremy vs Justin cage match!
Old 09-19-2013, 09:50 AM
  #265
if upgrading to the 3.7 manifold and 3.7 throttle body, OBVIOUSLY, you need more air.
thus why we stepped up to a 4 inch intake and discontinued using the "aem" 3.25/3.5inch intake for the 3G TL.
we do have a very great thread started by I Love Cars, that details every single item, every single increase, every single detail that you could ever singly need.
Old 09-19-2013, 09:56 AM
  #266
Any HP gains with that? or just quicker response?
Old 09-19-2013, 09:58 AM
  #267
FamilyGuy's Avatar
Can you link that thread here? Thx
Old 09-19-2013, 10:02 AM
  #268
HP gains, yes.
is it worth it?
$500 dollars on intake manifold upgrades is a lot of coin.
i'm trying to find the link.
story.customz (09-19-2013)
Old 09-19-2013, 10:03 AM
  #269
Ah, that $500 will definitely be allocated elsewhere, thanks! lol
Old 09-19-2013, 10:04 AM
  #270
Wait...is it a single thread?
Well, aside from being mildly butthurt when I responded...I appreciate your retort. What I was mainly trying to understand is why it would matter to feed more air to the 3.7...I doubt a factory 2012 TL SHAWD has a much bigger air tube into it's TB.
I feel like for all the money we spend on these engines and this that and the other bolt on, we see marginal results. Most of my modding is done because it's cool looking, sounding, or cheap enough to not mind giving it a shot.
Old 09-19-2013, 10:21 AM
  #271
FamilyGuy's Avatar
3" = 76mm
4" = 101mm
How big is the stock TB vs the 3.7?
Old 09-19-2013, 01:06 PM
  #272
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
LOL
The thread is call IIRC 3.7IM, ZDX TB, Runners or something of that nature
Old 09-19-2013, 01:12 PM
  #273
EvilVirus's Avatar
Nevermind I forgot I have it bookmark. Here is the link:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/my-3-7-mani-zdx-tb-pnp-runners-build-thread-870327/
Old 09-19-2013, 01:14 PM
  #274
^thanks evil
https://acurazine.com/forums/showthread.php?t=870327
and family guy, if stock throttle body is less than 76mm? lol because it is. I bored the stock throttle body out to like 78-80mm, I forgot.
and the 3.7 throttle body is at 78-80mm already.
Old 09-19-2013, 01:19 PM
  #275
EvilVirus's Avatar
^ and it bores out to 83-85mm i think (the 3.7tb)
I could check mine when I get home
justnspace (09-19-2013)
Old 09-19-2013, 01:21 PM
  #276
^thanks for your input.
I was fighting an up hill battle for a minute here.
Old 09-19-2013, 01:23 PM
  #277
So at 80-83mm the stock intake tube or even a traditional 3" CAI and filter become the limiting factor instead of the TB itself and a 4" intake is now necessary to keep the TB/Engine from suffocating?
It just seems to me that the logic is being applied to one application and then goes out the window with the use of a slightly larger TB.
Old 09-19-2013, 03:36 PM
  #278
FamilyGuy's Avatar
Alright cool
3.5" is ~89mm
3.25" is 82.5mm
I don't really see why we need a 4" intake system. I'd say 3.5" and up should be fine.
rockstar143 (09-23-2013)
Old 09-19-2013, 03:44 PM
  #279
not necessary at all.
stuff the most air you can at the throttle body
Alright cool
3.5" is ~89mm
3.25" is 82.5mm
we dont need a 4 inch intake but we've seen gains with a 4 inch intake
take everything i say with a grain of salt, as Im still on the 3.2 manifold. albeit, ported and polished with a bored throttle body with the stock intake sans resonator.
Old 09-19-2013, 03:46 PM
  #280
usdmJON's Avatar
Celebrity Death Match?
ILX. But same thing when it comes to the intake and many other things.
And no subie either. Just tore the front lip off one and stuck it on my ILX.
Thanks. I talk a lot of shit but I try not to talk when I don't know. When we say walk on the moon am I catching the right vibes?
Though in this case I jumped to conclusions. I'll explain in a second.
I was talking about the TL. But honestly the intake is the same exact thing. Well the placement of the TB might be different. But its a similar box to probably the exact same resonator.
It does. But as I said I jump to a bit of a conclusion.
I didn't realize you guys where still using some sort of ducting to locate the airbox inlet away from the engine further. I literally though you guys had the airbox with an open hole on the bottom and that is all.
If you guys got some ducting, spectre sells some, you could relocate the intake tube directly to the bumper with something we had for our integras.
trololololol
It acts as the ducting toward the outside of bay. Yes it's main function is noise dampening but without it there isnt as direct of a connection from the intake to the outside air.
Quick Reply: Intake Resonator Removal REVIEW
