Factory IM Spacer - 17108-RDJ-A00
Old 06-17-2009, 11:45 PM
  #281
Bored at work
tl2slow's Avatar
am taking mine to get milled tomorrow...am going to try 3/4 ....you guys think thats enough????
Old 06-18-2009, 04:30 AM
  #282
beachexotic03's Avatar
Originally Posted by NedShneebly
Getting a constant CEL since installing: P0137 and 2207 - 02 lean bank sensor codes. I got the 0137 once before since installing pre-cats but it was random and never came back after clearing. I cleared this code twice now and it's back within minutes of driving around.
Might have slight surging at light throttle application. Just ran the car at Test and Tune night locally and it did good considering it was 93 degrees air temp (pro'ly 110 track temp), it's an auto, and I have 19's: 14.860 @ 95.13. Cars running very good wide open but it's not adjusting so smoothly. I'm sure the CEL is a combination of the pre-cat's and spaced IM. I can actually hear the induction noises from the IM in the cabin...sounds pretty killer!
Did you forget to hook up the CPS sensor i wonder? Also maybe you didn't hook up a ground or something sounds weird! I have no Cel's
Old 06-18-2009, 04:32 AM
  #283
I think you should give it a try and dyno it then we will deside if the milling is worth the money?
Old 06-18-2009, 07:47 AM
  #284
practicing nihilist
NedShneebly's Avatar
Originally Posted by Dave_B
Exactly. It's humerous people are refering to it as "bitching". The way I see it is most people aren't willing to turn their classy TL into a ricey drift-look car with a popped hood. Some guys like the popped hood look, but for me, it's plain silly looking. Modifications almost always are about compromise whether it be ride quality, noise, or driveability. But the compromises with the look and potential damage far outweigh the gains. I'd be really concerned about that hood clearance if you get some excessive wheel-hop or if some other party closes the hood. You're talking $1000+. If the OEM is aluminum, you're looking at even more. Ball peen hammers to the underside support rails? Good God. By the spacer and take it to a machine shop for milling (~$50-100).
"humorous"
I think it's humorous you provided the link showing how the 350Z guys have the same product and now you're knocking it. I don't fall victim to the placebo affect of mod fever - this mod yields noticeable torque.
The hood pop, like you can see in the pictures above, isn't nearly as in your face as I thought. Meaning, only tuners would even notice it. I've never noticed a pop hood because I'd never seen or read of it before but, last night at the track I started seeing it on a couple of the imports. I would only mill 1/4" to ensure clearance and not compromise effectiveness and I don't think anyone is going to fit more than 5/16"s of spacers with the length of the latch bolts.
And a ball peen hammer was my answer to not cutting the frame rails completely out. Hoods plenty rigid and you don't have to worry about denting the pretty part of the hood as it will never impact if you smack on the rails. FYI - our under hood support rails are factory crimped in a couple areas to clear certain parts. I just added a couple more.
I ran hard all night at the track and drove over crappy backwoods roads all day and night getting there. Slammed the hood shut about 30 times since then, as well. There is no concern of hood creasing, denting or flying up at speed.
Old 06-18-2009, 09:32 AM
  #285
94 DC4 RS LSV/Turbo
stillhere153's Avatar
what I love now is that everytime someone's got the mild hood pop... everyone's guessing "running the im spacer" .... HOOD POP'N FOR THE WIN FELLAS
remember a few years ago when "pop your collar" was popular
"pop your hood"
Old 06-18-2009, 10:05 AM
  #286
Dave_B's Avatar
What link did I provide? All I talked about was the plenum spacer for the VQ which is an entirely different setup. We do have 3/4" intake manifold "spacers" excatly like what you guys are running, but they're simply designed for guys running forced induction who need the extra space for larger injectors. The spacer doesn't gain any power.
As for hood popping, the only people I see doing that are the 240 and Civic guys. I'll it at that
So you ran 14.8s@95mph last night. Do you have any other times to compare? Density altitude in Jacksonville ranged from 2200' at 5pm to around 1800' by 9pm. Those conditions were sucking out about .2 to .25 seconds and 1 to 1.5mph. Can you post your entire slip? What about your previous best slip?
Old 06-18-2009, 10:09 AM
  #287
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
does anyone have a pic of how this relo's the mount of your CAI??? i have the fujita and just wondering where i would have to bolt it up now... and i was thinking that now the IM is higher, it should pull the whole CAI higher up (away from the rear of the fog lights for us 07+) which is good!!!
Old 06-18-2009, 10:43 AM
  #288
Former Whyner
RonJonTL757's Avatar
"pop your hood"
I hear ya AL,
Lets set everyone straight!!!!!!
Old 06-18-2009, 11:23 AM
  #289
practicing nihilist
my bad, Dave. Someone else posted the Nissan spacer link earlier in this thread.
My 1st and best run was at 7:35 pm. I was reading 91 degrees on the dash in the inspection lanes. I don't have a camera at the moment and my blackberry isn't getting enough detail. This is the 1st time I've run the car so I have no base line time. Only knocking .25 second off my time is a bit dissapointing. I was hoping to be in the 14.3 - 14.4's if I could get a perfect run. Releasing the brake and stabbing the throttle was slow. General Exclaim's hooked up pretty good on about a 3/4 pedal stab off the line and I really only spun once.
Mixed 2 gallons of 103 with approx 3 gallons of 93 (103 was the lowest octane available).
Old 06-18-2009, 11:31 AM
  #290
practicing nihilist
My AEM V1 just barely made the stretch but mine was previously chopped about 3/4" for the Throttle Body spacer. Just had to loosen the frame support nut a little and be patient with the connector boot. If AEM has a boot that's 1/2" longer, I could use that.
Old 06-18-2009, 11:44 AM
  #291
Former Whyner
Im dying over here waiting for Acura and BMW to call me saying that my parts are in.
  #292
gerzand's Avatar
Mines a Fujita, guy. Check the pics I posted a few pages back. No modification needed.
Old 06-18-2009, 11:45 AM
  #293
Dave_B's Avatar
A 14.8@95mph in those conditions on 19s is really good for a TL 5AT. I'd imagine in the fall/winter when temps are in the 50s, the air drier, and the baro pressure is high, the DA will be easily below sea level which is a really good thing. Super dense air. That's why the fastest are always on coastal tracks in the fall/winter. Sea level altitude and super dense air. It's basically like having a 2psi supercharger. My guess is the car has a 14.3-14.4@98mph+ in it on OEM 17s and an excellent DA. That would be the fastest NA 5AT TL I've ever heard of.
What were your 60 foots like?
Old 06-18-2009, 12:19 PM
  #294
practicing nihilist
thanks for the reassurance. I saw a mazdaspeed running 14.4's and he had 16" drag slicks on front with OEM 19's on the back. I will definitely go with light 18's next wheel change but I can't sacrifice looks entirely.
that 60' run was 2.398 and best was 2.344. I didn't bust 15 seconds all night and consistency in a daily driver is nice. slowest pass was 14.987 out of 5 runs total.
Old 06-18-2009, 12:23 PM
  #295
practicing nihilist
Originally Posted by ACU-RATE
Well Put...
Here's my hood pop.......Get over it !!!
I've been meaning to comment on your car. Very mean looking ride. I'm normally not a black or A-spec fan but that is one of the tightest TL's I've seen. Is the grille completely removed?
Old 06-18-2009, 12:35 PM
  #296
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
Nice Ron, nice.
Old 06-18-2009, 12:49 PM
  #297
Former Whyner
BMW called and my bolts are in. Too bad I ordered 9 when I only need 7
Old 06-18-2009, 01:26 PM
  #298
practicing nihilist
did anyone list the BMW part #'s? And are you guys getting the 2 studs through them as well? if so, part #'s for them, as well. Thanks
Old 06-18-2009, 01:31 PM
  #299
gerzand's Avatar
Ned, good buddy. Is there any hope left?
Old 06-18-2009, 01:33 PM
  #300
Mjakaz09TL's Avatar
Old 06-18-2009, 01:37 PM
  #301
practicing nihilist
i'm lost. hope for what?
Old 06-18-2009, 02:17 PM
  #302
Former Whyner
Part # and people are leaving the stock studs in to line up the spacer and just using the 7 bolts. It will hold.
Old 06-18-2009, 02:19 PM
  #303
Former Whyner
no, they can't. these Studs are threaded on both ends so they can be sunk in the block and then capped inside the intake manifold with nuts (they're the two with nuts inside the IM when you take off the "3.2 Vtec" cover).
If you must do it now, just order 7 bolts and keep the 2 factory studs in place. Two of us have done this now. It will serve as a guide for the lower gasket and spacer but you won't be able to get a nut on it. 16 lb ft (or 196 inch lbs) each of the 7 studs and they hold fine.
Clean the EGR ports, IM and throttle body while you're in there.
Old 06-18-2009, 02:59 PM
  #304
Real Cars Have 3 Pedals
ACU-RATE's Avatar
It's the ebay grille delete...
I bought it from another 04 TL owner who backed out on the install.....Ever since he saw my install, the guy been KICKING himself for sellin it...lol
Its made for the 04-06...So i have to do some custom work to make it work for my 07 TL-S....its not perfect up close...BUT still lookz better than stock..IMO
Old 06-18-2009, 03:16 PM
  #305
Ryan Christopher
Black_05_TL_6SP's Avatar
Originally Posted by Black_05_TL_6SP
For those that don't feel like reading the whole thread. I have compiled the list of parts needed and what they are. I looked up the correct studs and added that part #.
Factory Intake Manifold Spacer (1 Required) - 17108-RDJ-A00
Bolts 8M x 105mm (7 Required) - 95701-08105-08/ BMW part for the 8M x 105mm Bolt 07-11-9-904-532
Studs - 8M x 100mm (2 required) - 92900-08100-1B
Intake Manifold gasket (1 required) - 17105-RCA-A01
This was one page back! I gave all Honda parts, as well as the BMW parts.
Old 06-18-2009, 03:56 PM
  #306
Dave_B's Avatar
Nearly 2.4 60 foots? There's a more hope for your car than I thought. Are you spinning or is it bogging? Why can't you put the OEM 17s back on the front for drag racing? Your TL should surely be able to get a 2.2 60' in cooler air and on smaller rims. That alone would drop the ET by another .2-.25 seconds.
Old 06-18-2009, 09:09 PM
  #307
practicing nihilist
I've been wrenching on my car for 3 days straight and trying to chase a kid around all night. My mind is oatmeal at this point. Mom need to get back in town.
Old 06-19-2009, 07:32 AM
  #308
Ryan Christopher
No problem, it is understandable.
Old 06-21-2009, 01:12 PM
  #309
practicing nihilist
Got a steady "P0137" code. Comes back within minutes of resetting. It translates to "O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)". This time it also showed a "P0137 pd", not sure what that means.
Do I have an 02 sensor going bad?
Old 06-21-2009, 01:20 PM
  #310
practicing nihilist
Just did some searching and .com guys get these codes when they install race headers. Makes sense with my cat deletes but I only got this code once before installing the spacer.
Oh, and they can lock this code out with the kpro ECU replacement...lucky bastards
Old 06-22-2009, 05:22 PM
  #311
Former Whyner
Got my spacer in!!! ill post pics later. Ouchie to my manifold 3.2 cover and my hood support even with 3 washers. Looks like im gonna need the dremmel
Old 06-22-2009, 06:42 PM
  #312
Former Whyner
Big Big Thanks to Totalacura (Adrian) for helping out with the install in 95 degree weather. Had a few small issues especially with the factory strut bar because it was rubbing against the brake booster line and it actually split it so I dont have the bar in for now.
Also if you dont reset the ECU after the mod you might get a CEL like I did but we reset it for 5 mins and it was all good.
Some hoses were a strech but everything was fine. Car pulls harder but my stock exhaust is really killing me Thanks again Adrian
Sorry for the pics they are from my crappy Instinct.
Spacers, Spacers, Spacers....oh my
Popped hood FTW
Side angle
Wanted to see where it was hitting.. I have kids so a crayon FTW!! and scratches FTL!!
You can see where its hitting and im going to dremel that peice out which should do the trick.
P2R+MDX spacer+OEM spacer
Front view with the elevated manifold. Looks like a beast!!
3 washers on all 4 screws. Im thinking about 4...
Bonus while we were at it mod TB Bypass
Old 06-22-2009, 07:35 PM
  #313
Green Machine
t0talacuratl's Avatar
^No problem E. Glad you satisfied with it. I see you got the stock on already.
Old 06-22-2009, 10:01 PM
  #314
practicing nihilist
Nice pics, RonJon.
So, have you driven it enough to notice a lot more induction noise from under the hood? I know, obviously, but my car is starting to act a little sick. Got a code that won't clear - reset ECU 3 times now - but it's not very serious. Getting a belt or pulley squeak now at low rpm's/idle and it seams that the 2 larger pulleys visible looking on passenger side of engine are moving a bit excessively - in fact, the entire engine has a rythmic shake that is visible and I can feel the engine quite a bit inside the cabin.
Maybe it's just time for a couple things to come to a head. Not trying to discourage and will only remove this spacer to possibly get it machined down 1/4". Car runs very hard at even partial throttle and my mileage is surprisingly good. This mod is dope for low/mid range torque.
Oh, I think I got 5 washers in and I still have some slight rubbing even after hammering on the support beams a bit.
Old 06-22-2009, 10:47 PM
  #315
gerzand's Avatar
Nice pics, RonJon.
ned, take a pic of ur engine bay for me. I would like to see something that I think may be causing your rumbling issues.
Old 06-23-2009, 03:22 AM
  #316
Hahaha. I know what everyone is doing The hose to the back of the manifold will cause a CEL Plus not grounding. I have drove 1000 miles on spacer no CEL
Old 06-23-2009, 07:17 AM
  #317
practicing nihilist
What exactly do you want a picture of?
You mean just little pressure the strut bar is putting on that hose is causing roughness? That woul be nice if it were the fix but I think its a reach. Don't see how that would be related to the 02 sensor. Well, if my friend can shave a 1/4" off it won't be an issue.
I know some of the roughness is due to the contact with hood when closed but I did a slow drive with the hood popped and it wasn't that big a difference. I'm mostly worried about the squeak and shuttering.
Old 06-23-2009, 08:07 AM
  #318
94 DC4 RS LSV/Turbo
this is not a sarcastic statement
dude you know your shit
Old 06-23-2009, 08:43 AM
  #319
gerzand's Avatar
Yes, a pic of this area. But its not just the tubing i'm looking at. Just do it
Old 06-23-2009, 02:26 PM
  #320
Check out my other project in the racing section.
Quick Reply: Factory IM Spacer - 17108-RDJ-A00
