Factory IM Spacer - 17108-RDJ-A00
Old 11-02-2009, 11:50 AM
  #681
gerzand's Avatar
So, with the spacer removed and my stock mani on the car, my car went back to its old self (Not much low end) however the top end was still pretty healthy for what it is due to the RV6 pre-cat deletes
After installing the PnP'd mani and removing the Im spacer, the entire power band is now much more healthy all around, namely the sub 3k and >5k ranges.
For example, going up a 20 degree incline for a highway entrance ramp which I drive multiple times a day....the low end (2500-2900rpm) gets the car up and going much quicker and with much less effort. You dont feel the motor strain or "let off" due to the weight of the vehicle.
To add to this, the top end is a different animal as well. Typically when shifting into 3rd at WOT, there would be a slight pause in shifts when nearing redline---as where now, the car just flies into 3rd with no letting up. Let me put it like this....If had sound deadening headphones on I wouldnt even know I had shifted into 3rd yet, because acceleration is that seamless now between thee gears.
Say im exaggerating all you want, but im loving is... and im nowhere close to my 350whp magic number yet.
Old 11-02-2009, 07:07 PM
  #682
practicing nihilist
NedShneebly's Avatar
what's all the PnP work costing you. or didn't you have a P2R hook up?
Old 11-02-2009, 07:27 PM
  #683
gerzand's Avatar
I dono if I had a hookup price or not... so ill jsut say call them and ask
Old 11-02-2009, 07:28 PM
  #684
Jokerman
jokerman826's Avatar
ok, my question. I am looking at getting a supercharger. How would getting this mod done affect the placement of the supercharger.
Old 11-03-2009, 07:36 AM
  #685
Ryan Christopher
Black_05_TL_6SP's Avatar
It would throw the alignment of the intake tube from the SC to the manifold off. I would not worry about doing this mod with a super charger. You could do this mod if you wanted a bit more low end until you get the charger, since it is fairly inexpensive.
Old 11-03-2009, 09:54 AM
  #686
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
why would you get a half ass'd tuned supercharger when you can get a tested and tuned turbo for around the same price ???
Old 11-03-2009, 10:08 AM
  #687
gerzand's Avatar
Im not even doing a supercharger so you cant say im taking sides... but "about the same price"? How is 3k for a used supercharger at ALL equal to 6k for the turbo kit? Spend $500 on a meth kit and ur golden. $3500 OTD.
Old 11-03-2009, 10:29 AM
  #688
swoosh's Avatar
i thought the SC was $4500....and me being me, i rather spend another $1000 and get a completely tuned and tested Turbo.....
those guys on the same turbo but higher boost are making close to 550-600 whp.....which is almost twice of where a supercharger gets u.....
again this was to JOKERMAN....there are a lot many options you have for this car....but then again for some people (include me) this is a daily driver and i dont think am in for either supercharger or turbo or meth or anything which forces my car to stay in the garage for prolonged periods.....i dont mind bolt on's .....
and gerz i think you have more knowledge than I do when it comes to flow and compression and all that and hence you have a mental picture of where PnP will take u.....and all i can say it all the best.....lemme know how it holds up !!!
Old 11-04-2009, 05:56 PM
  #689
Jokerman
Isn't a supercharger better for the A/T. And i thought the turbo put too much pressure on the engine what other mods need to be done for the turbo kits to not screw up the engine? And would the spacer work for this, cause if i do the spacer mod until i get the money to do either forced induction kit i dont think i would want to remove it.
Old 11-04-2009, 06:29 PM
  #690
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
All the info is here on this site in the turbo thread.
In a nutshell, the turbo is easier on the engine hp for hp. If you're going forced induction in the future don't waste your money on other mods now. You will be able to make more hp than the stock bottom end can hold with just the turbo. Anything you spend right now is a waste.
Old 11-05-2009, 12:33 AM
  #691
Dave_B's Avatar
HP is HP, and for the most part is irrelavent to your question. You should be more concerned about how the power from the forced induction application is delivered. With regards to the safety of FI in general, BUYER BEWARE. Adding FI to an NA motor is always a risk, with some motors are riskier than others. The motor in your TL was made to rev and get it's HP from rpm. The pistons and connecting rods are light and relatively thin so that the motor can rev high and rev fast. The compression ratio is also pretty high. FI-designed motors are usually more robust and not quite so eager to rev when the turbo is online. The FI motors tend to have lower compression ratios, heavier duty blocks, rods, pistons, head gaskets, cooling systems, etc. They also have big injectors to 1) keep up with the increased air flow and 2) keep the combustion chamber cooler (ie fuel lowers combustion chamber temps which reduces detonation).
The things you need to concern yourself with if going FI is:
1) Motor strength (ie rods, pistons, head gaskets)
2) Cooling, more HP means more heat
3) Fuel, are the injectors up to the task
4) Tuning
Out of all those, tuning is the most crucial ESPECIALLY with a turbo. Usually what kills most FI-NA motors is the onset of boost. Newer turbos are extremely efficent. They ramp up quickly and can deliver boost within a few hundred rpms. That means the motor could go from 120whp to 250whp in a matter of 500rpms. That 500rpms is where it's basically do or die. If your tuning is poor, that big wallop of power with inadequate fuel could cause catastrophic failure due to detonation and send a snapped rod thru the block. It would happen so fast you most likely wouldn't have enough time to release the throttle. These types of failures are common place with bad tuning. Then there's the question about the motor strength. Light and thing pistons and rods, tend not to lend themselves well to FI, especially turbos and over the long term.
Overall, the best FI setups are turbos. They're efficent and greatly increase overall power band, increasing torque and HP at every point of the powerband.
Centrifugal blowers, like those from Vortech or Procharger, deliver their from rpm. The more rpm, the more HP. The power delivery is linear, just like an NA motor. You feel no real boost surge. Instead, the motor just keeps pulling. HP is increased a good bit and torque not so much. A 400whp centrifugal motor won't be remotely as fast as a 400whp turbo motor because the turbo motor will have far more power under the curve. The centrifugal advantage is it's easier to tune and a bit safer.
Roots/screw-type blower like that from Comptech deliver strong low and midrange HP and torque, sometimes better than that of a turbo, but the roots setup becomes inefficent as the rpms increase because of the massive amount of heat the screws generate. The advantage of these blowers is reliability, ease of installation, and are somewhat easy to tune.
Old 11-05-2009, 01:42 PM
  #692
4) Tuning
See Dave, we can agree on some things.
Mine goes a little rich as the turbo is spooling to prevent any lean spots. It hurts spool by a few miliseconds but is worth it for reliability.
One thing you touched on but did not elaborate is the low rpm spool that many modern turbos are capable of. This greatly increases cylinder pressure and stress on parts. It's one of the many reasons I prefer an auto with a semi-high stall convertor for a turbo application.
Old 11-07-2009, 03:43 PM
  #693
Jokerman
Cool thanks for the help. to both of you, i hate cars and dave, thanks
Old 11-22-2009, 02:08 PM
  #694
minkl81's Avatar
Originally Posted by Richie v6
Does anyone know if this is back in stock yet from honda?
why not start selling milled down version with correct bolts?
Old 11-22-2009, 08:49 PM
  #695
wham bam thank you ma'am
Rajca's Avatar
getting the spacer isnt the problem, the bolts are on back order.
Old 11-22-2009, 09:02 PM
  #696
J36Twingt28r's,nextgt30r
tenzingsherpa's Avatar
i still can't say how much i love this mod!!! im an auto and spin my tires as soon as im on the gas. a must have mod in my book. but i would invest in some hood spacers if u want the most benefit!!
Old 11-27-2009, 09:43 PM
  #697
Fear and Loathing in my
Timb227's Avatar
Are these bolts still on backorder? Has anyone ordered any of these parts through any Acura website and received them quickly?
Old 11-27-2009, 10:05 PM
  #698
Rajca's Avatar
from what ppl are telling me, their on back order. takes weeks to get in. im sure u can find them at a hardware store somewhere, but none around my house had long enough bolts.
Old 11-27-2009, 10:07 PM
  #699
Timb227's Avatar
Ah that sucks. Ill have to take a drive to the stealership tomorrow and order all the Acura parts. Then see if BMW has them in stock?
Old 11-29-2009, 12:46 PM
  #700
Former Whyner
RonJonTL757's Avatar
Get your MDX spacer and Bolts from me
Hey guys I just took my spacer off and have it FS in the BM. No need to wait weeks for these bolts.
https://acurazine.com/forums/car-parts-sale-361/3g-parts-mdx-spacer-stock-gasket-oem-shift-knob-754035/
Old 11-29-2009, 01:12 PM
  #701
Bored at work
tl2slow's Avatar
hey pm Timb227....hes wants it
Old 11-29-2009, 01:30 PM
  #702
Former Whyner
Hey he hit me up already. He just wants me for my bolts... lol
Old 11-29-2009, 10:44 PM
  #703
SteezusChrist's Avatar
hmmm anyone know if this mod works with the 8th gen accord engine? (J35Z2)
Old 11-29-2009, 10:48 PM
  #704
Former Whyner
PM Stillhere153 (AL) he knows everythinggggggg
Old 11-30-2009, 05:13 PM
  #705
94 DC4 RS LSV/Turbo
stillhere153's Avatar
Yes but you will have to get it portmatched to the 8th gen runners, they are much wider I believe
Old 12-01-2009, 02:02 PM
  #706
gerzand's Avatar
I'd be very interested to see a pics of this, just for kicks....
I mean, because are they only wider on the Malifold side? Or also on the Head sides?
If wider on the head side as well, thats VERY interesting because may indicate some room for performance gains with a set of 8th gen heads and runners....assuming the heads are the same CC.
Old 12-01-2009, 11:39 PM
  #707
ah i'd definitely do it, but i don't know of any shops here in utah that'll do the porting work.
Old 12-04-2009, 07:39 PM
  #708
9th Gear
worldon1finger's Avatar
This is such a great mod. I put it on my car and noticed the difference right away.
Old 12-05-2009, 09:12 PM
  #709
Modding my TL in
xcelir8TL's Avatar
As an FYI - the mod is going strong in this Chicago weather. Still very pleased.
Old 12-05-2009, 09:36 PM
  #710
Rajca's Avatar
hell yea, ive never seen u in any of the meets. where u at?
Old 12-05-2009, 10:01 PM
  #711
Modding my TL in
xcelir8TL's Avatar
Working.
Old 12-18-2009, 09:36 AM
  #712
BigJack75's Avatar
Double ditto batman!!!
Old 12-18-2009, 09:54 AM
  #713
Inaccurate's Avatar
--//-- RV6 IM Spacers --//--
Triple ditto batman!!!
RV6 - please consider offering a milled-down IM spacer. Milled down to fit with no hood modifications required.
You could also offer a version of it with pre-fitted direct-port NOS Foggers (6 foggers) already installed in the spacer and plumbed with the metal tubing.
Old 12-18-2009, 10:03 AM
  #714
Inaccurate's Avatar
I just sent Richie a PM regarding this business opportunity.
Old 12-18-2009, 10:26 AM
  #715
HQTL6SPD's Avatar
Would be a good idea! Especially for those who don't wanna cut their hood, add spacers, want to modify their engine covers to fit...
Earlier in the thread I asked how much would need to be milled off the spacer to achieve this, but no answer... so not really interested until this mod can meet the proper specs.
I hope Richie makes it happen
Old 12-18-2009, 01:07 PM
  #716
gerzand's Avatar
Its because the answer has been posted here before. Its 7-10mm and varies by how much motor lash your car exhibits.
Old 12-18-2009, 01:27 PM
  #717
swoosh's Avatar
recently i have seen a lot of people selling their MDX spacer....hard to believe all are aiming towards PnP....any drawbacks....i mean people were cutting their hood for this and now selling it off !!! ???
Gez....350 whp...damn son !!!!congrats !!!
Old 12-18-2009, 03:41 PM
  #718
gerzand's Avatar
It's because people r PnP'ing their stuff. lmao
Old 12-18-2009, 03:42 PM
  #719
swoosh's Avatar
^^^ recently i have seen more MDX spacers in BM than anything else....
just wanted to make sure before i throw it on
Old 12-18-2009, 03:49 PM
  #720
gerzand's Avatar
Thing is, they are for sale because when you pnp your mani and/or runners its of no use to have the MDX spacer. It actually hurts your top end, as RonJonTL757 found out before he realized it couldnt be used. New he's amazed
Quick Reply: Factory IM Spacer - 17108-RDJ-A00
