Factory IM Spacer - 17108-RDJ-A00
#361
gerzand, I believe that is the vac solenoid for the Vac assisted motor mounts. The Booster hose is the big hose on the right in that last pic. The one that isn't connected because it hits the strut brace. Just to clarify...
#362
If you want the spacers milled/thinned out, I could talk to Richi @ the CNC shop and see if he'd be willing to help out and do it at no cost. If someone wants to try it, take it to him and send it back to someone willing to send me it...
#365
Former Whyner
#366
The point is YOU DONT WANT TO. It will tear itsself up over the long run as well as cause increased engine noise/vibration. I know because ive experienced it already. hehe k?
#368
Nikon Neck Beard Krew
Too many fitment issues for me, and im not gonna mill it down or cut my hood so my kit is for sale.
1x Spacer
2x Extended studs
7x Extended bolts
https://acurazine.com/forums/car-parts-sale-361/mdx-intake-manifold-spacer-mod-kit-3g-tl-732984/
1x Spacer
2x Extended studs
7x Extended bolts
#369
1x Spacer
2x Extended studs
7x Extended bolts
https://acurazine.com/forums/showthread.php?t=732984
1x Spacer
2x Extended studs
7x Extended bolts
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
![Rave](https://acurazine.com/forums/images/smilies/trance.gif)
#370
Green Machine
1x Spacer
2x Extended studs
7x Extended bolts
1x Spacer
2x Extended studs
7x Extended bolts
#371
Former Whyner
Big Thanks to stillhere for promoting this mod! Well done Plus 1 goes to you. For the rest of pep's read the thread before you ask anymore questions. For everyone so fucused on the cutting part of the hood. All i have to say is mods dont come easy.Maybe you should focus on your Gf to make her happy since your being such pussy's!
I'm done with this thread!
Maybe ill be the one to start the
on the DIY 3.7 Camshaft install.
O well im down for the
#372
Green Machine
#373
LOL!!!!!!!!! I've laughed at this thread like 3 days in a row now. Classic.
#376
Are you saying that a CEL will occur with this solenoid missing ? If so, this is not true.
I studied the wiring diagram in the service manual before removing mine. This solenoid is a "dumb" solenoid, meaning that the ECU recieves no feedback from the solenoid. The ECU is unaware if the solenoid is attached or missing. The ECU just sends voltage to this solenoid, and the ECU does not check for a closed-circuit or anything signal in return.
I have had my solenoid completely off of my car since I install my IM motor mounts. This was many thousand miles ago and never have I had a CEL.
#381
practicing nihilist
well there's yer problem right there!
![](http://i466.photobucket.com/albums/rr21/ugawd/pre-catfailure.jpg)
found the source of all that noise I've been complaining about. weld finally broke completely Friday night and it was stoopid embarrassing loud. car feels all tame and slow now.
^beach, awesome pull on the dyno. 6MT? 250 at the wheels on my 5AT would be very gratifying.
My spacer will go back on soon. Oh, and I removed the hood spacers. Not for you "pop" haters, but because I have some serious warranty work coming up and I'm not giving the dealer any pull to point the finger.
Piece
#384
practicing nihilist
i left the heatshields off the stock cats since I don't plan on them staying on very long. think this is gonna hurt anything?
#385
Chapter Leader (NY/NJ)
WOW ned. thats crazy. AcPimpin got a crazy noise out his cats too ima have to check his welds not that i see this.
beach got some good numbers. would love to drive it to see how it compares to mine.
#388
94 DC4 RS LSV/Turbo
Naaaaaah leaving the heatshields won't cause no problems, they would lower temps a slight bit, but the stock cats actually don't retain heat
Can't wait for richie to release the v2 of the precat deletes
#390
practicing nihilist
#391
94 DC4 RS LSV/Turbo
yes it is... they will be out soon
as for resonated precat deletes.... the heat coming out of the motor will melt the resonated walls and it would end up sounding like ass...
#392
practicing nihilist
Kinda tired of hearing 'resonated', myself. Let it Breathe!
Rich rules. He's gonna hook me up with the V2's. Says their thicker and have better 02 sims.
Back to the thread, I did want to share that this mod vastly improves throttle response. I've been noticing how mushy the pedal is since I removed the spacer - even with the hole in that was in my rear down pipe.
#393
Green Machine
#394
because he had thought it might have been the reason for the noise he was getting which actually ended up being his failed precat delete.
Ned, I'm actually still waiting on a set from Richie too due to failed welds, but around the flanges in my case.
Im excited that my wait on the V2's completion since March is almost over tho.
#395
practicing nihilist
like gerzand said, thought it was the source of my problem since it started right around the time I installed it.
true, true! Sounds like he strengthened them and upgraded the defoulers. My defouler bungs were corroding, baby-shit green like an old nickel or the Statue of Liberty before they re-painted her. Code's gone, too.
The thing that has me grinning about the pre-cat failure is I ran it at the track with the beginning of that weld breaking. It was running strong but, maybe I could have posted a bit better number without the exhaust dump. Is that what electronic cutouts sound like? Cause it sucked! Baby's so quiet now I wish I hadn't put that Aero resonator on my ATLP...
Im excited that my wait on the V2's completion since March is almost over tho. ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
#397
Real Cars Have 3 Pedals
I do have my hood popped..pics is on page 7...But its alot more flushed now compared to the PICs...now that ive adjusted the hood latch some & removed the P2R IM gasket & add the OEM gasket
Yes, I did some cutting to the hood frame...prolly alot more than some to make room for the ENG cover.
