Where's the factory keyless module
Old Dec 14, 2006 | 10:44 PM
revo's Avatar
Back in the saddle..again
Anybody know the location?
Old Dec 14, 2006 | 11:15 PM
Ron A's Avatar
Administrator
It's behind the driver's dashboard lower cover.
Old Dec 15, 2006 | 12:01 AM
revo's Avatar
awsome thanks
Old Dec 15, 2006 | 03:01 PM
triggle's Avatar
'04 6mt Pearl
From Sunnyside acura the "control unit (cabin)" under the left side lower kick panel. Item #7 is the receiver unit.
Planning a mod ?
Old Dec 19, 2006 | 08:17 PM
revo's Avatar
Yeah,
Actually on my Remote Start I want to connect the Piezo Siren that chirps to confirm the door locks are locked. I want to connect the Remote start horn output to this so when I lock and unlock it chirps that horn rather than the regular horn. Also I want to see if I can extend the range using an external antenna
Old Dec 20, 2006 | 09:52 AM
triggle's Avatar
'04 6mt Pearl
The keyless unit receives the RF keyfob data, decodes it and sends a driver1,2,3, lock unlock, disarm, trunk or panic signal over a 2-wire bus to the MCU. The MCU drives the
piezo or speaker.
The simplest way: Pick up a new piezo (speaker not buzzer) at rad shack, connect to your remote start unit and listen to it. As I recall piezo are like speakers so you send them an audio signal not just a voltage. This means the tone pattern of the TL chirp is likely generated by the MCU not the piezo. If your remote start unit generates a pulse train rather than just a voltage then a piezo might sound okay.
Search the web for the tech info on you remote or call their tech support and ask if it is compatible with a piezo speaker.
Old Dec 22, 2006 | 10:17 AM
revo's Avatar
Thanks I will do that
Old Jan 18, 2007 | 03:04 PM
MadJap's Avatar
Planning a mod ?
I wonder if we could mod the receiver with an antenna (a piece of wire accross the lower dash perhaps) to extend the pathetic range of our remote fobs?
Anyone wanna try?
Old Jan 18, 2007 | 05:43 PM
datmrman's Avatar
It would be easier just to stick the fob up to your chin: Increased range for factory key fob?
Old Jan 26, 2007 | 10:40 AM
MadJap's Avatar
Though that has worked well for me in the past (with OEM and Clifford fobs), I get no love from my TL fob. I would rather mod it to work better than get a little irritated when the chin trick doesn't work.
Old Jan 26, 2007 | 12:38 PM
rbf351's Avatar
Registered User
if you open the keylless entry modul, you'll see the antenna is just a peice of metal that is shaped like a square, i'm guessing you can just tie a peice of wire to that
Old Jan 26, 2007 | 12:43 PM
rbf351's Avatar
Registered User
Originally Posted by revo
Yeah,
you can always tape directly into the stock buzzer which is located in the driver side fender
part 16
Old Jan 27, 2007 | 12:28 PM
rwpow's Avatar
Do you know where the VSA yaw-rate sensor is? Not planning to mod (risky!), just wanted to see it. I used to work for a firm that designs/builds them, wanted to see who made this one.
Old Jan 27, 2007 | 08:02 PM
triggle's Avatar
'04 6mt Pearl
Anyone wanna try?
Just about any mod to the antenna should yield an increased range due to the stock location of the receiver located behind sheetmetal in the left footwell.
There are 2 ways to mod that might be considered.
1 - extend the 4 wire harness of the module and relocate the whole keyless box which is quite small. Relocation into a more central area of the car near the console may be enough but I think if there is less sheet metal near the Rx then it should work better.
2 - crack open the Receiver module and solder an insulated 24 or 28guage wire to the existing antenna wire and route it to an open area of the car, like under the dash. The Receiver unit is easily removed and the circuit pulled out without any tools. I can't say what wire would work best but it would need a good insulator so it does not short to any metal bits. Personally I'd try a single strand of the CAT5 UTP (blue jacket) which is solid core not the patch cord variety which has stranded conductors.
Usmcgrunt47
Oct 13, 2023 09:35 PM
rcs86
Aug 2, 2016 06:52 PM
SUPRMN84
Oct 7, 2015 09:46 PM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
