Subwoofer & Amp Installation - TL Wiring Diagram anyone?
Old 08-06-2010, 02:19 PM
John08TL-S's Avatar
Lightbulb Subwoofer & Amp Installation - TL Wiring Diagram anyone?
I'm looking for a wiring diagram so i can us a line converter. I've gotten the rear deck off but i can't figure out which wires are positive and negative on the rear speakers. I'm also still considering simply using the signal for the stock subwoofer to run the aftermarket sub. Would that be too much power for the converter? Also the signal to the factory sub is already crossed over, i'm thinking i might be better off with the full range signal and using the crossover on the aftermarket amp.
What does everyone think?
Most importantly, does anyone have a wiring diagram for the Acura TL's rear speakers?
Because I've spent quite a while researching this the past few days, I thought I would also provide a handful of links that have helped me get up to this point (seat removal, running power wire from battery, ect)
Help With DIY Amp and Subwoofer install - https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/help-diy-amp-subwoofer-install-644820/
When removing rear seat back, is it necessary to remove bottom part as well? - https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/when-removing-rear-seat-back-necessary-remove-bottom-part-well-728095/
DIY: Aftermarket Amp Install - https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
Need Help, Advice, Anything...adding Sub - https://acurazine.com/forums/audio-video-electronics-navigation-22/need-help-advice-anything-adding-sub-185395/
Mounting Amps and still using the trunk? - https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/mounting-amps-still-using-trunk-580019/
Sub + Noise Cancellation - https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/big-problems-need-help-sub-noise-cancellation-609759/
Complete Audio Installation - https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/tech14-complete-audio-installation-643839/
For what it's worth, here are the items being installed:
Any help would be appreciated, and hope the above links are also helpful..
-John
VegasMike007 (04-14-2015)
Old 08-06-2010, 02:25 PM
Received 16,265 Likes on 11,974 Posts
Remove factory sub. reach hand in hole and grab the two wires. one will be postive the other negative.
Grab your LOC and twist the two positives together. do the same with the negative wires. now connect the positive end of the LOC to the positive wire of the sub. do the same for the negatives.
now connect RCAs to the LOC to amp.
Be sure to disable your rear noise canceling mic as it will cause interference with the sub.
Old 08-06-2010, 02:28 PM
1islandparadise's Avatar
Here are a few pics of my install. I also explain how to wire up the LOC(line output converter) with a picture. I just installed my subs, only a few weeks ago.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/subwoofer-install-help-784007/
Saddac06 (03-21-2017)
Old 08-07-2010, 03:28 PM
John08TL-S's Avatar
Which fuse did everyone use to run their amp's remote wire off of? Everything i've tried so far is keeping the amplifier on while the car is completely off..
Old 08-07-2010, 04:25 PM
John08TL-S's Avatar
Nevermind, we tapped into the fuse that is on in the #32 ACC position.
Old 08-21-2010, 10:52 PM
John08TL-S's Avatar
Does anyone have a speaker wiring diagram for a 04-08 Acura TL?
Old 08-22-2010, 02:31 PM
A SiQ TL's Avatar
This gives the speaker wire colors to and from the factory amp
Originally Posted by spyfish007
You ask and you shall receive ....
@ the Stereo Amplifier in the passenger kick panel in the 20 pin Black & White connector
RF+ Black
RF- Gray
LF+ Green
LF- Blue
C+ Brown
C- Greeen w/White
RR+ Orange
RR- Red
LR+ White
LR- Yellow
SW+ Red w/Blue
SW- White w/Green
Remote Turn-on -> Red w/Yellow
Amp Mute -> Yellow w/Green
In addition ....
@ the Stereo Amplifier in the passenger kick panel with the 14 pin gray connector contains the speaker outputs if you want to utilize the factory wiring.
RF+ Blue
RF- Red
LF+ Light Green
LF- Purple
C+ Green w/White
C- Blue w/Yellow
RR+ Red w/Blue
RR- Yellow
LR+ Brown w/White
LR- Red w/Yellow
SW+ Yellow w/Black
SW- Light Green w/Red
Ground -> Black
+12V -> White
heyitsnickk (10-08-2015)
Old 08-20-2012, 08:51 PM
NWSTL's Avatar
Bumping a 2-year-old thread for a correction. The last two wires listed and their properties should be switched. SW - Green w/red is positive, yellow w/black is negative.
Old 10-09-2012, 02:49 PM
AndrewA's Avatar
Bumping again for correction of the correction. The Sub wires are correct as above, not as NWSTL indicates. The service manual shows yellow-black as POS and Light Green-Red as NEG.
Old 06-21-2013, 11:00 AM
triax37's Avatar
Potentially embarrassing NOOB question: the LOC I purchased (below) has +/- input wires for both the left channel and right channel (4 total wires). Do I connect the yellow/black and green/red from the stock harness to the LOC's "left" channel, "right" channel, or other? Sorry to be stoopid!!!
http://www.parts-express.com/pe/show...number=266-004
Old 06-21-2013, 11:46 AM
JJH
JJH's Avatar
Depending on your amp, you may not need a LOC at all. No idea about the wires....the amp that I purchased I'm just running straight from my stock amp.
rubenders (09-15-2014)
Old 04-02-2018, 09:48 AM
emegge23's Avatar
I would like to know what is the purpose of the 12v cable and ground that appear in the gray connector of 14 pins.
Old 03-14-2024, 06:55 PM
5th Gear
cyrus2468's Avatar
Amp diagram
Help With DIY Amp and Subwoofer install - https://acurazine.com/forums/showthread.php?t=644820
When removing rear seat back, is it necessary to remove bottom part as well? - https://acurazine.com/forums/showthread.php?t=728095
DIY: Aftermarket Amp Install - https://acurazine.com/forums/showthread.php?t=580314
Need Help, Advice, Anything...adding Sub - https://acurazine.com/forums/showthread.php?t=185395
Mounting Amps and still using the trunk? - https://acurazine.com/forums/showthread.php?t=580019
Sub + Noise Cancellation - https://acurazine.com/forums/showthread.php?t=609759
Complete Audio Installation - https://acurazine.com/forums/showthread.php?t=643839
-John
Does anyone have the wiring diagram for the Amplifier in a 2004 Acura TL?
Cyrus.
cahuxf13@gmail.com
AndrewS
19
03-14-2024 06:59 PM
02-25-2020 09:57 AM
Soul_Deamon
11-13-2018 04:44 PM
BoricuaTL
04-08-2016 01:08 PM
not nice
09-05-2015 02:41 PM
Quick Reply: Subwoofer & Amp Installation - TL Wiring Diagram anyone?
