Replacement Speakers
Can anyone recommend a brand of good sounding aftermarket speakers that will go well with my stock radio and sub? Thank you for any input y'all may have.
KCCO
If you are replacing only the speakers and leaving the amp and such alone, then make sure you buy 2ohm speakers, as that's what the stock are. If you buy 4ohm they may be quieter. I think that's how it works?
stock speakers are actually less load than that. tweets are 4 ohm and the door speaker are 2 ohm, wire in parallel for a total load of 1.33 ohms to the amp.... the stock amp works better at lower impedance too (more power, less distortion) If going with aftermarket drivers it would be hard to find ones that will work better than the stockers on the stock amp.
i'm having the same question. i bought polk slims 651s for the rear but those suckers don't fit and idk what to do with them now i've been looking for adapters but i can't seem to find any.
KCCO
https://acurazine.com/forums/audio-b...-depth-556521/
This is a good thread that shows the specs of the ELS stereo system. About 1/3 way down the first page Mancur shows the size, wattage and impedance of the speakers. The rest of the thread has a lot of good info as well.
Fearless DIY Guy
You can use the following as direct replacements as I did. The tweeter upgrade will yeild the largest improvement.
TWEETS - Infinity Reference 1031t
MIDS - JBL 662s
CENTER - Infinity something (I forget)
There is no need to upgrade the rear soundstage and is simply not worth the investment. Save the money and add some sound dampener to the front doors.
MIDS - JBL 662s
Fearless DIY Guy
I took my car to my local audio shop and had JL Audio 6x9's & 6 1/2" front & rear deck speakers installed. I'm running the stock amp to power the speakers and they sound great! I will be upgrading the amp soon Also have 1 15" VM Audio Sub sealed in a pro box for that bass
I want to replace the tweeters in my 04 TL. I put in a new touch screen Pioneer and I'm wondering whether to go with a 4 ohm or a 2 ohm. Guy at the audio shop said I should go 4 ohm and that's probably what they are anyways. I wanted to get the infiniti speakers but the reference 1031t are discontinued. Which infiniti would be best with the stock amp and aftermarket head unit?
AndrewS
19
03-14-2024 06:59 PM
Pegon95
09-15-2015 01:54 PM
