Rear deck enclosure????
Old Dec 30, 2009 | 12:09 AM
HarlemzFinest135's Avatar
I use my trunk all the time but want to get some subs put in the trunk but can't afford to sacrifice the trunk space. My question is has anyone tried to make or install subwoofers on the bottom of the rear deck.
Old Dec 30, 2009 | 05:25 AM
jptl04's Avatar
Bone stock tl-s
It's been done with a single 13" sub uncald4 did it I believe.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/2007-tl-audio-finally-done-745316/
Old Dec 30, 2009 | 09:30 AM
Thanks man I'll look him up.
Old Dec 30, 2009 | 06:27 PM
uncald4's Avatar
Former Sponsor
I've done twin 10" subs up under the rear deck as well.
Old Dec 30, 2009 | 07:52 PM
Kool I'm looking to do something like that. My idea is to put 2 JL audio flat subs in it. I was looking for 2 10"s but the smallest JL makes is 12's. 12tw5 I believe they're called. But how much would something like that cost because I have a guy who does cheap fiberglass for me but I'd rather go with someone who's done this exact car before. No surprises you know.
Old Dec 31, 2009 | 11:43 AM
uncald4's Avatar
Former Sponsor
I would not recommend doing anything larger than two flat 10" subs under the rear deck. Honestly two 8" subs are ideal for that location. You want as little subwoofer movement as possible. The 13TW5 we did caused too much vibration across the rear deck and C-pillars. When we tested the double 10" enclosure we lost a lot of the flex and rattles and were able to sound deaden the car to an acceptable level.
Cost would be around $300 for a double subwoofer enclosure under the rear deck.
Old Dec 31, 2009 | 12:35 PM
I like to have tons of bass in my car and I usually go with 2 12" subs but like I mentioned before I really need the trunk space. Also I'm not really worried about the rattling I'll just dynomat the whole rear deck and the c-pillars. I sent you an email with some questions.
Old Dec 31, 2009 | 05:39 PM
BoxOn20s's Avatar
I picked up a box made by Uncald4 using a single JL 12w3v2 and a JL G1700. I have the gains down to 1/3 on the amp and its almost too much. At full power the bass is ridiculous. He really knows his stuff and his craftsmanship is top notch. On top of that, his enclosure uses up very little space. It actually fits inside of the small trunk net.
Old Dec 31, 2009 | 06:25 PM
Sweet.... Can you post up any pics I'm curious to see what the enclosures look like
Old Jan 1, 2010 | 12:32 PM
BoxOn20s's Avatar
Heres a link to his post with plenty of examples of his work. https://acurazine.com/forums/sponsored-sales-group-buys-10/custom-fiberglass-subwoofer-enclosures-358676/
Old Jan 1, 2010 | 02:56 PM
uncald4's Avatar
Former Sponsor
Thank you for your compliments. Always appreciated.
Dynamat will not cure the rattles induced by mounting two 12" subs under the rear deck. The movement of those bigger subs actually flexes the rear deck and C pillars. Totally not worth it. My basic rule is... either you have big subs or you have trunk space. You can not have both.
Old Jan 2, 2010 | 07:48 PM
CSWBiggs's Avatar
I second that...
-Jason
Old May 24, 2010 | 08:35 PM
jrsmiles's Avatar
Has anyone built a single 10" sealed box out of MDF to suspend from the rear deck?
Dec 7, 2020 05:39 PM
iesu3423
Oct 6, 2015 06:54 PM
Sep 17, 2015 09:01 PM
Dunnik
Sep 15, 2015 11:52 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
