Front Speaker Removal & Instalation?
Old May 16, 2010 | 02:12 PM
Ropski's Avatar
Just bought a pair of Alpine type S for my newly purchased 06 TL base. Cant find any vids of how to remove the speakers (blown driver side). Wondering if I have to take the whole door panel off or what. Or a simple list of steps lol.
Old May 16, 2010 | 03:51 PM
Nick337's Avatar
check in the faq section, they have a diagram for taking the whole door apart which you have to do.
Old May 16, 2010 | 04:22 PM
shellready's Avatar
#1 you should use the search feature
#2 check here https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/3g-tl-audio-electronics-faq-605299/
Old May 16, 2010 | 08:01 PM
A SiQ TL's Avatar
yes, you must remove the door panel.
use a small screwdriver to remove the black plastic panel behind the door handle,
remove the 2 screws behind that panel,
remove the screw in the arm rest above the map pocket,
remove the screw and the rubber bump stop on the end near the door light.
grab the panel at the bottom and pull towards you , popping all the plastic clips,
lift the panel straight up over the door lock button,
and finally remove all the wiring harness'.
set aside and easily remove and replace speaker.
Old May 24, 2010 | 10:35 PM
TL Luver's Avatar
2006 6spd
will you post here/pm let me know if you get louder sound just by replacing door speakers?
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
james357
Feb 13, 2016 02:37 PM
08 NBP TL
Sep 8, 2015 08:49 PM
